I was de-winterizing the camper last night (2011 Rockwood 8317SS). Swapped the suction hose from the little lead hose I dip in the antifreeze to the hose coming from the tank, turned on the pump, and started to empty the antifreeze from the various faucets and fixtures. At the same time I was filling the tank with a garden hose (no hose fitting, just had the hose pushed into the fill hole about 2", see pics). After I seemed to have gotten all the antifreeze out of the interior fixtures, I went out to get it out of the exterior shower wand. That's when I noticed the tank was overflowing, and I pulled the hose out. Water started shooting out of the fill hole, and probably a gallon or two spurted/spilled out before in finally stopped. At that point I noticed when I turned on a faucet, the water was spitting a lot of air and the pump wasn't shutting off, even when the faucet was off.
I shut the pump off and reconnected the lead hose I use for suctioning the antifreeze and dipped it into a full bucket of water to see if I had pump problems. I turned the pump back on and opened the faucet, and it sucked the bucket dry just like it was supposed to. When I reconnected the tank hose to the pump, it was getting a little bit of water thru, but was sucking mostly air.
Could I have overfilled the tank and possibly blown the hose partially off where it connects to the tank? Or is there a check-valve I could have destroyed? And how in the heck do I get to it to find the problem???
1st camping trip of the year starts Friday, so I need to get something figured out, stat!
Matt
