Old 10-19-2014, 10:20 PM   #1
Pump surging
My water pump will come on for a couple of seconds every couple of minutes. I have looked and can not see any leaks. It just started this weekend. Had it out 2 weeks ago and no problem. I think it has to be a loose fitting but none have been found. Any help appreciated.
Drexel 2012 is offline   Reply With Quote
Old 10-19-2014, 11:12 PM   #2
Put newspaper under those fittings that have a flat area under them. Any water leakage will darken the newsprint almost immediately.
jimdic is offline   Reply With Quote
Old 10-20-2014, 04:19 AM   #3
arpipeliner's Avatar
Have u bled all the air from hot water tank till it's clear and not bubbley or foamy looking?
A few campers had that at one campground on a well with little pressure. We ran the hot water side on the kitchen and bathroom (shower and sink) till solid water and it went away. Guess there was a pocket of air in the top of the on about 3 of the 6 campers. Something to try if u are not finding any leaks but uses a lot of water if dry docking. We were just using to have pressure while his new well pump came in.
arpipeliner is offline   Reply With Quote
Old 10-20-2014, 06:20 AM   #4
TURBS's Avatar
You should purge air from the hot water system at the pressure relief valve.
Turbs
pump
