11-25-2015, 12:46 PM
#21
RV pumps are self-priming. That's why when you empty the FW tank and refill it, the pump will re-prime and you get fresh water from the FW tank.
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
11-25-2015, 01:23 PM
#22
We too had a similar issue with the 5th wheel we own. the winterization line would not pickup the antifreeze from the 2 gallon jug.
removed the line off the filter and then removed the filter.
cleaned any residue from the filter and reinstalled.
my RV shop gave me an adaptor to fit the filter 3 yrs ago and i attached it directly via a clear tube i picked up at the hardware store and threw the switch.
completed my winterization. BUT...
when i reattached the factory line and attempted to do it again... the antifreeze blew out the city water inlet.
DLW was not impressed with her pink hair.
So i think i have a bad back pressure valve which may have caused an unforseen issue. it will be replaced when it hits +15 degrees again. 5 months from now.
TV 2018 Ford F250, hauling a 2018 KZ 331 TH 12 Sportster 5th wheel, packing a 2015 CF MOTO 800 U-Force SXS
11-25-2015, 02:11 PM
#23
pump won't pull antifreeze
Our V lite has a valve next to pump that blocks antifreeze from entering your fresh water tank. Turn this valve and pump will pull antifreeze from the source and distribute it in your filter and water lines.
11-25-2015, 02:13 PM
#24
No one ever told me about this valve and nothing in owners manual just found it on my own.
11-25-2015, 02:15 PM
#25
This valve has been discussed many times in the prior 20+ posts of this thread.
The OP even posted a photo of his.
11-25-2015, 02:23 PM
#26
I have a 8289 WS. There is a valve, a small black one near the pump. When you have it set correctly it will draw anti freeze from the outside port labeled anti freeze by the city water connection. I set a gallon container and connect the siphon tube and connector to the anti freeze port and dangle the tube into the jug of anti freeze. My DW, with one walkie talkie switches the water pump on and opens a faucet until it comes out pink. We donut with each outlet including the outside shower and the other shower and then put some in the traps. I use about 3 gallons total. Don't forget the toilet.
Pontiac Dan
2015 Rockwood Signature Ultra-Lite 8289 ws
2015 GMC Crew Cab 2500HD Gas:
11-25-2015, 05:00 PM
#27
What I had to write down as a reminder on my Columbus 5th wheel is: After turning bypass valves and draining the HW Heater, make sure the HW Heater is completely plugged and air tight for purposes of pumping antifreeze! The pump will not pull antifreeze if, for example, the pressure release valve on the Water Heater is open or, there is no airtight plug where the Anode port is located. (When I winterize, I take out the Anode and use a 3/4" pvc plug)
Hope this helps!
11-25-2015, 05:26 PM
#28
Hope this helps!
Interesting.
I thought the water heater was out of the picture once it has been bypassed.
11-25-2015, 05:41 PM
#29
Originally Posted by Ford Idaho
Interesting.
Well, I did too but I stuck the anode back in and tried it anyway. Still no go. Bummer. I thought maybe the solution had been found!
So RingoRoy, why do you put a plastic plug back in instead of the anode after it's drained? The manual talks about the pressure relief valve but I don't see anything on any of the diagrams that locates it. Is that the thing in the outside access panel that looks like a water faucet? If so, the pin in the end of it seems to be seated but I didn't pull on the "handle" thing dangling.
Geez, I had no idea there was so much to know about maintaining this thing! I'm gaining more appreciation than I already had for my husband when he was here to take of all this!
2015 Rockwood Mini Lite 1901
2017 Ford F150 EcoBoost
11-25-2015, 05:47 PM
#30
Yes it is.
11-25-2015, 06:22 PM
#31
Thanks for all your responses. I really do appreciate it.
So this morning I have verified that I have the valve in the correct position by pouring antifreeze through a funnel into the antifreeze inlet and it filled the pump's filter screen reservoir. Below is pic of my valve. Line going up goes to AF inlet and the one going left goes to FW tank. I again looked for a second valve on the FW line and didn't find one so I'm assuming this valve closes it off. I capped my low water drains which I hadn't done before. And I filled the hose/inlet line with antifreeze, put my finger over the end and placed in a bucket of antifreeze. Still won't pump the AF in. I had one faucet (cold water side) open while trying this. I did let it run a short time with the faucet closed but I didn't think you were supposed to run a pump without liquid so I didn't let it run long.
Again, the pump seems quieter than other campers we owned so at this point I think there's something wrong with the pump itself. Any other thoughts?
Sounds like your sucking air . pump will be quite sounding and you will get know where . check the filter for tightness along with other down stream fittings
11-25-2015, 06:29 PM
#32
Thanks Ford Idaho, for showing the pic to Terri of the Relief Valve. Terri, I take the anode out of the heater to clean it in 50/50 vinegar/water. We could just put it back in once it's cleaned, but we decided that when we get ready to de-winterize, we can quickly hose-flush the tank through that anode port, then replace the anode at that time. I guess it has turned into one of our idiosyncrasies, but it's easy to check on the status of the anode and cleanliness of the water heater.
ANYWAY -- back to the topic of pulling antifreeze....when we have the hose in the antifreeze container and the pump is on, (sorry I forgot to mention) we make sure that none of the faucets are on, and YES, the water heater SHOULD be isolated, but in our case, we need to make sure it really is via as I previously posted. The pump SHOULD prime the line, but it might help to open/close a line until it does. I think someone already mentioned the water filter container....with the filter out, the container must be tightly in place as well. If all of the lines are primed and the faucets are OFF, the pump should have stopped running too. At that point, we turn on, one at a time, each faucet, shower and supply line to bleed it until antifreeze pours through.
I hope this really clarifies and helps.
Blessings and best wishes
11-25-2015, 06:33 PM
#33
Interesting.
It is.
As long as the bypass valves are in good working order and are oriented in the correct positions for bypassing, the rest of the plumbing system will never know the water tank exists.
11-25-2015, 07:28 PM
#34
Originally Posted by 5picker
It is.
As I suspected, when I winterized the lite I left the Atwood's drain plug out to check for A/F in the tank incase something went south.
Everything worked as it should have(sheer dumb luck) I reinstalled the plug to keep bugs out.
11-25-2015, 08:18 PM
#35
Exactly, the pump works because it is making a "more quiet" sound, being it is not under load of moving water. Just try what I suggested. It will force water to the pump, prime it, and if that is the problem, you should be back in business. I understand others have their belief on pumps are self priming, but following the simple procudure suggested might get you back on track. Just sayin'
11-26-2015, 10:27 AM
#36
I had the same issue - thought all my valves were turned the correct direction - except one it was the one nearest the pump I turned it the opposite direction of what I thought and it started to suck up the pink stuff.
11-26-2015, 11:06 AM
#37
Hope this helps!
Sorry, but this makes zero sense. The HWH is on the discharge side of the pump. If you've properly bypassed the HWH, then the pressure relief valve and anode/drain hole are isolated from the rest of the plumbing and their position doesn't matter. If you haven't properly bypassed the HWH, then the pressure relief valve or anode/drain plug being open is no different than having a faucet open.
The only thing that will prevent the pump from pumping (assuming the pump itself isn't FUBAR and it is running) is either 1) the pump is sucking air somewhere or 2) the pump suction is isolated from the suction source. Both issues are on the suction side of the pump.
2011 Traverse LT, 3.6L, FWD
11-27-2015, 08:06 PM
#38
I just wanted to say thank you to everyone that responded. I still need to try Still Kickin's suggestion but with the rain we're having for days, it will be a bit before I can get someone here to help me. I have gotten an adapter to use the compressed air method to winterize and if I don't get the pump working before the freeze, I'll just blow out the lines, pour in the antifreeze and disconnect the lines to the pump and the toilet valve to try to make sure any remaining water flows out. Hopefully that will be enough.
Thank you all again for your time and assistance!
11-28-2015, 11:12 PM
#39
Pump won't pull antifreeze
I don't think anyone has mentioned putting some water back in the FW tank, flipping the valve, open a faucet, and see if the pump still works. If it does, flip the valve again to winterize and open a faucet. (In fact you could leave that same faucet open and just switch the valve over.) If the pump runs but doesn't pull antifreeze in the winterize mode, then the problem lies between the pump and the antifreeze draw tube and probably excluding the common line to the pump that is used for both modes, i.e., a hole, crack, loose hose connector or bad (or partially open) valve.
Land of 10,000 Lakes
2016 Forester MBS 2401R
2016 FR Forester 2401R
Towing 2014 Honda CR-V
11-29-2015, 02:51 PM
#40
It's a long thread and a lot to read, but yeah I already tried the fresh water tank. Doesn't pull from there either. The last I turned it on before all this was when I tested right after buying it last March. I usually camp in campgrounds with water hookups so haven't needed it!
Still waiting for it to quit raining to do anything else...
