Old 10-21-2015, 06:41 AM   #1
Put RV antifreeze in city water connection?
I just read a comment on another thread where someone mentioned putting the RV antifreeze into the city water connection when winterizing. That is the first time I have seen that mentioned. Should I do that when I winterize my Sunseeker?
2014 Sunseeker 2860DS
gmacklem is offline   Reply With Quote
Old 10-21-2015, 06:52 AM   #2
RSchleder's Avatar
I've owned 12 different RV's and have always done my own winterizing. I have never put anti-freeze in the fresh water connection and never had a issue.
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 10-21-2015, 06:58 AM   #3
Semperfi24's Avatar
I have an RV Antifreeze connection underneath the city water connection. Last year, I used an old hose that I was able to cut about 5' of length. Attached it to the antifreeze inlet, put the other end into the rv antifreeze bottle, turned on the water pump, and then you just turn on the faucets (one at a time), as well as flush the toilet, etc, and the pump did the rest
_________________________
2018 Rockwood Mini Lite 2504S
2018 Ford F150 Lariat Special Edition 3.5 Ecoboost
Semperfi24 is offline   Reply With Quote
Old 10-21-2015, 07:13 AM   #4
Georgia Rally Coordinator
aceinspp's Avatar
Same here for my 6 campers I've owned. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10 gear
Days camped 2017 62
Days camped 2018 67
Days camped 2019 30
Old 10-21-2015, 07:21 AM   #5
5 units and never have put antifreeze in the city water connection. Never an issue.
With that said, I always blow mine with compressed air so I'm confidant nothing is in the city water connection anyway.
Days Camped: '16=46 '17=30 '18=51 '19=32
Old 10-21-2015, 07:30 AM   #6
fonzie's Avatar
X2
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 10-21-2015, 07:31 AM   #7
If you use your RV pump to Winterize your unit it will Backfeed A/F into the City water fill! That is why you (Depress the Check valve at the City Hose Connection) to allow A/F to also discharge at this location! Youroo!!
Old 10-21-2015, 07:47 AM   #8
Alleged curmudgeon
Vern's Avatar
I have never used my City water connection, which may explain why I have never heard of this. However, I blow mine out with air each year before I use the RV pump and factory anti-freeze pick-up to winterize the lines in my Windjammer. What is this check valve at the city water hose connection to which you refer?
Lee
2013 Windjammer 3008W
2006 Chevy Silverado 2500HD 6.0L w/Equalizer 4
Nights camped: 2012 (29); 2013 (26); 2014 (40); 2015 (43); 2016 (35); 2017 (34); 2018 (39); 2019 (22)
Vern is offline   Reply With Quote
Old 10-21-2015, 07:48 AM   #9
camper1999's Avatar
I do my own winterizing and I might be paranoid but I put antifreeze in the city water connection, the black tank flush, and any where else I can think of. I do this after blowing out the lines. All this takes me an extra 15 minutes which to me is a good trade off for having a water line break somewhere where it is hard to get to.
2011 GMC 2500HD Diesel
Old 10-21-2015, 07:50 AM   #10
deebarjay's Avatar
not talking winterizing.....when you connect up to city water [say at a camp site], when you open kitchen or bathroom faucets, your pump doesn't start up right?...or does it?
2008 F250 6.4 diesel with 50 gal aux tank towing a 2015 Rockwood 2109s Minilite.
2015 Miles and nights
10040/31
2016 miles and nights
feb. 380/7......march 540/3
deebarjay is offline   Reply With Quote
antifreeze, water, water connection
