Old 05-07-2012, 07:53 PM   #1
pvc sink fittings
I had a leak under my sink and ended up taking out the pvc fitting that connects to sink drain and also the 90 degree bend. The part that connects to sink drain has a free floating threaded attachment. I ruined this during my adventure to fix leak. Anyway, where does one find these black pvc fittings & attachements. Tried a big box store but that was a waste. I would prefer to buy local if possible.
PremierOwner is offline   Reply With Quote
Old 05-07-2012, 08:51 PM   #2
Lowes or Home Depot?
Old 05-08-2012, 06:41 AM   #3
Tried the big box stores (Lowes / HD)
Old 05-08-2012, 06:48 AM   #4
TURBS's Avatar
Old 05-08-2012, 06:55 AM   #5
Fire Instructor's Avatar
If the big blue or orange boxes don't have what you need, try a respectable plumbing supply house. Bring the part(s) with you, so thay they have something to match-up. At the worse case, they can fit you with the appropriate size Fernco fitting Fernco Couplings, Flexible Couplings, Flexible Pipe Connectors, Fernco Fitting, Shielded Couplings, Fernco Donut, Pro-Flex Coupling, Large Diameter Couplings, Sewer, Drain, Waste, Plumbing Flexible Couplings, Plumbing Pipe Leak Repair | Fernco , and that will repair the damaged piece(s).
Fire Instructor
2014 RAM 2500 Laramie 4x4 Quad Cab w/Cummins Turbo Diesel, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
Fire Instructor is offline   Reply With Quote
