Old 04-03-2014, 11:57 AM   #1
Who Dares, Wins
doc73's Avatar
Question about adding hose bib to low point drain
As the title reads... Adding a hose bib to the low point drain. I purchased the bib and put it on and it leaks pretty bad. I to not want to crank it since it is only threading onto a plastic end piece. Should I wrap the plastic in Teflon tape? Do I need another type of adapter? I noticed the plastic gray cap has a white elliptical shaped "seal" in it. Is this key to my troubles?? I am no plumber... Pics below of the parts in question. Thanks!
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 04-03-2014, 12:09 PM   #2
Fulltime family RVer
See if this thread helps:
Sigh, lost low point drain caps (SabreSam?)
Old 04-03-2014, 12:55 PM   #3
Who Dares, Wins
doc73's Avatar
That IS very helpful and looks like what I was asking about. Thanks....
2015 ChevyHD D-Max
Old 04-03-2014, 02:21 PM   #4
Who Dares, Wins
doc73's Avatar
Added the Teflon tape and stopped the drip on the hot line. Have a once every 10 minute drip on the cold. I think I can be happy with that.
Sent from my SAMSUNG-SGH-I747 using Forest River Forums mobile app
2015 ChevyHD D-Max
Old 04-03-2014, 02:34 PM   #5
LOL, sounds like my setup. I still have a drip that isn't me!
Old 04-03-2014, 02:41 PM   #6
Who Dares, Wins
doc73's Avatar
Lol! I know the feeling...
2015 ChevyHD D-Max
Old 05-25-2014, 01:49 PM   #7
tjm
As the title reads... Adding a hose bib to the low point drain. I purchased the bib and put it on and it leaks pretty bad. I to not want to crank it since it is only threading onto a plastic end piece. Should I wrap the plastic in Teflon tape? Do I need another type of adapter? I noticed the plastic gray cap has a white elliptical shaped "seal" in it. Is this key to my troubles?? I am no plumber... ]
I just installed valves on my low points and tank. In addition to the Teflon tape, go to the plumbing section of the hardware store and look for Cone Washers. This will basically mimic the seal in the original cap. I have not had a single leak using these washers.
tjm is offline   Reply With Quote
Old 05-25-2014, 05:44 PM   #8
The low point drains are a flared fitting so you need an adaptor from NPT to flared fitting. Home Depot or Lowes can help you, take the cap and the valve with you.
Sent from my SCH-I545 using Forest River Forums mobile app
2007 GMC 2500 Duramax Crew Cab LB
2008 5th Wheel Cardinal 36LE
R Whitlow is offline   Reply With Quote
Old 05-25-2014, 06:08 PM   #9
That little plastic washer is a compression fitting and you should use a similar fitting, that will stop the leak.
higdonlg is offline   Reply With Quote
Old 05-26-2014, 07:31 AM   #10
Who Dares, Wins
doc73's Avatar
I had ended up putting on Teflon tape and it sealed all the connections. I will look for the cone washers though.
2015 ChevyHD D-Max
drain
