Old 05-16-2018, 05:56 AM   #1
Question about sanitizing
I flush the antifreeze from my lines and the ran the bleach/water mix through my system. I let it sit and emptied my fresh water tank. I'm going to fill the tank back up with water and flush that solution out of the faucets. Do I need to empty it again before flying the hot water heater and using the water? Is there enough bleach in the fresh water tank to taste?
Kevin, Julie (DW), 5 kids
2017 Roo 233s towed with 2009 GMC Sierra 1500 Crew Cab
kevin79 is online now   Reply With Quote
Old 05-16-2018, 06:06 AM   #2
Retired Navy
You should be good to go. I doubt you will have a bleach taste in your water after the second flush. I also flush the water heater out thru the anode opening using a flush wand designed for the purpose. I found I had some white crud collecting in the tank I did not want in my water lines.
2012 Lexington C Class
Toad: 2009 Honda Fit
Bob_K is offline   Reply With Quote
Old 05-16-2018, 08:47 AM   #3
It will be my first flush after the bleach, the second after the antifreeze.
Old 05-16-2018, 09:00 AM   #4
It should be fine as long as you didn't go overboard with the bleach mixture.
I always add in a little of this stuff when adding water to the fresh tank...
Camco Drinking Water Freshener.
Days Camped: '15=22 '16=46 '17=30 '18=51
Old 05-16-2018, 10:02 AM   #5
DouglasReid's Avatar
I have heard that bleach can harden the seals on the drain valves. I would not leave the sanitizing water in them any longer than is necessary.
2012 Wildcat Sterling 32RL, Gladiator Qr35 ST235/85R16 Load rating G, TST 507 TPMS w/ Flow-thru Sensors & Repeater, Reese Sidewinder 16K Pin Box
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Futomo Oil Drain Valve, Turbo Brake activated in Idaho Rob Heavy Tow Tune, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is online now   Reply With Quote
Old 05-25-2018, 12:18 PM   #6
Dirty Water System
I recently purchased a 2016 MAC Pop up tent trailer that has been sitting for a few years, and apparently has mold in the holding tank and pump. How can I safely clean all of that yuck out.
MoparMotorHead is offline   Reply With Quote
Old 05-25-2018, 12:31 PM   #7
https://www.rvtrader.com/research/ne...v-water-system
Id let it sit for at least a whole day, maybe longer til the mold is gone. Then flush well............several times
Old 05-25-2018, 01:03 PM   #8
Dave Lyon's Avatar
You should be fine, unless you used a lot of bleach as 5picker noted.
That's my routine and it's worked.
Dave, Southern,ON
2017 GMC SLT HD All Terrain Crew Cab (6' 6" Box) 2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
Dave Lyon is offline   Reply With Quote
Old 05-25-2018, 01:29 PM   #9
MillMitch's Avatar
1/4 cup bleach per 10 gallons?? Thanks, it's my first time sanitizing as well.
Mitch in MN
2018 Patriot (Grey Wolf) 23MK travel trailer
2011 Durango 5.7L and OEM tow package
MillMitch is offline   Reply With Quote
Old 05-25-2018, 01:52 PM   #10
MillMitch's Avatar
I found it, 1/4 cup per 15 gallons of water.
thanks,
Mitch in MN
