Old 02-23-2014, 10:22 PM   #1
El Camino Man's Avatar
Question on Freezing Pipes/Tanks
Hey guys. Im going to take my camper out for our first camping trip this year this weekend. Temperatures are... iffy. Mid to high 30s during the day and low to mid 20s at night. That's pretty chilly, but of course the heat will be going inside the camper. Should I just forget about using water or will it be ok as long as the insides warm?
1996 Ford F-250 XLT ECLB
Powerstroke Diesel, Automatic, 4wd
2003 Salem by Forest River 25RLSS
5er, 25ft, Super Slide
El Camino Man is offline   Reply With Quote
Old 02-23-2014, 11:39 PM   #2
rracer5's Avatar
1 - Is your underbelly enclosed?
If so, you should be OK with heat on. Maybe leave a faucet trickling.
If not, disconnect and drain hoses and lines (low point drains) until morning (turn off water heater if you drain everything)
Keep RV antifreeze in your tanks so they don't freeze
2 - Will you have full hook-ups?
Is so, see above and leave grey tank valve open so your tank doesn't fill up over night
If no sewer hook-up, see above
3 - Enjoy your weekend
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 02-24-2014, 12:01 AM   #3
H2o
Leave your water off. Unless you have a artic setup. You can use your toilet just flush with anti freeze. If you chance it you would have to leave all cabinet doors open to expose pipe to get heat.
use the showers at the place you camp. take extra bottle water with you.
Vacationman is offline   Reply With Quote
Old 02-24-2014, 12:57 AM   #4
kz08h5's Avatar
If the low temps are going to be below freezing make sure you disconnect your water supply hose. Things in the trailer will be ok with the heat going. If you don't disconnect the water hose you risk it freezing which can damage your trailer plumbing and the RV parks plumbing. I speak from past experience on this. If you have tank heaters turn them on when you set up. You don't want the tank valves freezing. It makes emptying the tanks problematic, which was another past experience.
Have fun.
kz08h5
2008 Chevy Silverado 2500 Duramax Crewcab
Jeep Commander - sold
Flagstaff V-Lite WRB26
kz08h5 is offline   Reply With Quote
Old 02-24-2014, 09:48 AM   #5
My biggest problem is the park doesn't officially open til march. The showers and faucets are locked so I have to fill my water before I leave and shower in the camper. The only hook up they offer is electricity and have a waste dump as you leave.
I havent actually been under my camper but Im fairly sure its all covered underneath
Old 02-24-2014, 03:30 PM   #6
MacDR's Avatar
Warming the Columbus Up
Hey Everybody,
I have a Columbus 340RK and will be leaving Wisconsin for Florida in a couple of week's and will de-winterise down South, I have Anitfreese in both Gray Tanks, waterlines and Blackwater tank.. Can I turn my Tankheaters on to warm everything up on the first day down to help thaw everything out?
MacDR is offline   Reply With Quote
Old 02-24-2014, 04:42 PM   #7
To answer your question, it shouldn't be frozen if you have antifreeze in it. But if you have tank warmers, then it wouldn't hurt to turn em on and warm it up
And I checked out my camper: it doesn't have an underbelly... I can see all 3 tanks. Now Im thinking I should take some cardboard and make an underpinning and put a space heater under it just to be sure
Old 02-24-2014, 05:02 PM   #8
MacDR's Avatar
Space heater...
Thanks for the thought.. I've warmed up the unbelly on an older unit with a space heater before.. I would use something other than cardboard for the pinning...
Old 02-25-2014, 04:37 PM   #9
I think I may have screwed up... I think I was told by the RV dealership that there needs to be water in the hot water heater before you plug the camper in or else itll burn up the heating element... I totally forgot about this and plugged in my camper. Is this true? Did I probably burn up my heating element?
Old 02-25-2014, 04:42 PM   #10
Old Bones's Avatar
On our TT just plugging in the trailer doesn't turn on the water heater. There is a switch at the water heater that has to be turned on as well.
If that switch isn't turned on you should be okay. But yes there needs to be water in the water heater before turning on the power switch.
2013 Forest River Surveyor SP296
Old Bones is offline   Reply With Quote
tank
