04-19-2017, 07:40 PM
Scoundrel
Question - Replacing City Water Connection
Before I tear into it and risk making things worse thought I'd ask here first.... I'd like to replace the fitting on my City Water Connection as the threads have seen better days. There are three phillips screws that are holding the fitting in place. Is it that simple to replace? Not sure what to expect when I start peeling the onion.. I bought my 2014 Micro-Lite used and haven't camped yet but hopefully soon. As always thanks for your advice.
Rich J.
04-19-2017, 08:38 PM
Can use a phillips but are actually square drive. I have pulled several out and not all were the same. Could be pex crimped/removable clamp/threaded etc.. Pull it out and see.
04-19-2017, 08:45 PM
Scoundrel
Thanks. I'll pull it apart tomorrow and see what I find. And yes, I'll use a square drive.
Rich J.
04-19-2017, 08:49 PM
Replaced one like that on my Coachmen. Holes lined up with original. Make sure you buy some butyl tape for the new install. 10 minute job.
Here is a link to OEM replacement.
https://www.amazon.com/JR-Products-1...ty+water+inlet
2015 F-250 FX4
04-19-2017, 09:10 PM
Scoundrel
Thanks Crunchman for the Amazon link. I just ordered one.
Love these forums.
Rich J.
04-20-2017, 09:57 AM
Replaced mine about a month ago. Via Amazon, bought a Valterra A01-0169lFVP, which has a brass threaded insert instead of the plastic threads.
Simple 10 minute install. Hose at rear threads on just like a faucet fitting. No pex or pex crimp needed.
Grumpy
Steve & Cheryl + Zoey, and Ziggy, our furry kids.
2012 Forrest River Lexington 283ts
Toad, 2013 Subaru XV Crosstrek
04-20-2017, 10:10 AM
Just as confused as you
Easy. Replaced mine last summer. The O-ring between the threaded part and flange had worked itself out part way and got to where it would not turn. I replaced it with a all metal one. Holes were a tiny bit off but not so you'd notice once assembled.
Richard & Jill
04-20-2017, 07:30 PM
Love these forums.
Rich J.
Cool, glad to help. Don't forget the butyl tape for install. Let us know if you have any issues.
2015 F-250 FX4
04-20-2017, 09:03 PM
Scoundrel
Thank you. It'll be a week before the new one arrives and I'll replace it then, and thanks to everyone who replied.
Rich J.
04-21-2017, 09:14 AM
AKA: 'tiredTeacher
Every one of us should have a #1 and #2 Robertson screwdriver for these fasteners. They're all over the units. Square drives and Phillipses will work if the fastener isn't too tight. Using a Robertson is the best way to go, IMHO.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
04-21-2017, 09:25 AM
Make sure you secure the hose when you disconnect it from the outside connection. If it falls back inside you could be tearing the inside apart getting it back out!
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
