Old 01-31-2015, 08:46 PM   #11
When we camp at a state park we found that have water faucet scattered around the CG for people to fill a pot or water can. They don't have threat connections to hook a hose to. I bought a water thief at Camping World and it fits over the end out the water faucet. I use a bunge to keep the water turned on and run several hoses to reach the MH. Most times I have done this other campers want to help and also fill up their tanks so water hoses are readily available. I also bought 6 6 gallon water jugs from Walmart and a 12 volt pump from Harbor Tool. I wired a switch and hook it to the batteries like Brother Les. That also works but much more work.
Old 01-31-2015, 09:40 PM   #12
Ret E-9 Anchor-clanker
donanddona's Avatar
Or make a special spout connection for the water can to RV. Or an adapter type funnel.
donanddona is offline   Reply With Quote
Old 01-31-2015, 09:48 PM   #13
Brother Les's Avatar
There is a check valve in it. Filling it up by gravity and adapter will not work very well at all. (tried it)
Brother Les
Old 01-31-2015, 10:04 PM   #14
dieselbobcat's Avatar
We have done most of these ideas...
carry up to 100' of hose when we have a idea that we will need it.
But my favorite method is the water bladder, have a 40 gallon soft water bladder that we lay in the bed of the truck. Watch camping world... they go on sale every now and then...
Portable RV Fresh Water Tank: 45 Gallon - New World CW1605 - Fresh Water Tanks - Camping World
9 times out of 10 we are able to siphon the water into the FW inlet... it is lower than the bed floor of our F150 on flat ground (sometimes will take 30min but sure is easy)
When the siphon is not possible, we use a modified hose (male - male) to connect bladder to winterize inlet. Then either "pump around" using shower route OR if we are not using the truck, just leave the bladder connected and pump directly out of it (since soft, it doesn't need venting, just collapses)
2014 Rockwood Ultralight 8312SS Diamond Edition
2016 F350 Lariat Ultimate Super Duty Crew Cab 4X4
Northern NJ - God Bless America!
dieselbobcat is offline   Reply With Quote
Old 01-31-2015, 10:09 PM   #15
I think this is the best bet if you have a truck. I have a MH so not an option.
Old 01-31-2015, 10:29 PM   #16
Kaadk's Avatar
Originally Posted by caper View Post
You could use the pump that is run by a drill. Low pressure and the drill could be corded or cordless.
X2. I picked up one of those at Princess Auto for like $4. Works in a pinch.
There's no use crying over spilt milk, unless it's on your keyboard.
Old 01-31-2015, 10:31 PM   #17
Brother Les
Are you saying there's a check valve in the FW tank fill line? That doesn't make much sense to me. I know there's a check valve in the city water line, but not the FW tank fill line.
2011 Traverse LT, 3.6L, FWD
Old 01-31-2015, 11:26 PM   #18
SKnight's Avatar
Mine has one too. No idea why, my only guess is it's the same connection as the city water hookup so they used it there to save on inventory.
Old 02-01-2015, 06:13 AM   #19
Computer Nerd's Avatar
Thanks for all of the great suggestions. I will take a look at some of these options. Thanks again!
Computer Nerd
2014 Chevy Silverado 3500 HD Duramax
2015 Sandpiper 35ROK
Computer Nerd is offline   Reply With Quote
Old 02-01-2015, 07:56 AM   #20
RPAspey's Avatar
Make yourself one of these and keep using the blue jugs. And you'll have a spare pump. I've used mine to also wash the dogs outside (I don't have an outside sprayer)
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
tank, water, water tank
