Old 02-01-2015, 08:23 AM   #21
mark0224's Avatar
I bought one of these to transfer the water.Heavy Duty Drill Powered Pump 650 GPH
or you could do this 12v Marine Utility Water Pump
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 02-01-2015, 06:32 PM   #22
Brother Les's Avatar
Originally Posted by rockfordroo View Post
Are you saying there's a check valve in the FW tank fill line? That doesn't make much sense to me. I know there's a check valve in the city water line, but not the FW tank fill line.
Yes, there is a check valve on the units that have the garden hose attachment set up. not so good idea imo. One of the first things that I noticed on my new unit, upon filling the Freshwater tank and when full and water flowing out the over flow. When shutting off the in coming water there was no way to burp the system and water because of the suction effect would continue to drain water out of my fresh water tank for a quarter to a half of the tank of water. The dealer tried to redo the breather tube to stop this, but it never worked. Also, traveling down the road, the sway of the unit would start the suction effect again and drain even more out of the tank. The one way check valve allowed and helped the suction effect. I ended up having to put a valve on my Fresh water tank breather tube, which I open when we set up camp. I consider my Fresh Water fill attachment and breather set up by Forest River as very Sub Par for such a company.
Brother Les
Old 02-01-2015, 08:38 PM   #23
Sounds like they just took a city water connector and stuck it on your FW tank fill line. I wonder if you can remove the guts of the check valve from the open end of the connector? (Maybe it would screw out?)
Camping World has 3 city water connectors. Two of them say they have a check valve. This one does not, and one of the reviewers says he's using it to connect a hose in his bathroom, which I would interpret to mean he's running water OUT of the connector instead of INTO it, which also implies no check valve.
Recessed City Water Inlet - Lakeview 3783 - Faucets & Inlets - Camping World
Maybe you can replace your FW tank connector with this one.
Another thought: I would assume you now have THREE of these connectors, one for city water, one for FW tank fill, and one for your anti-freeze. MAYBE they installed one without a check valve, but inadvertently put it on the AF connection.
2011 Traverse LT, 3.6L, FWD
Old 02-01-2015, 09:35 PM   #24
Lon
Lon's Avatar
Fascinating Reading
and answers a huge number of questions I have pondered as a newby over the last 5 months...especially the post by FROG(hope I spelled that right). So the winterizing port utilizes the water pump to suck antifreeze into the water lines. So I don't have to pour antifreeze into the fresh water tank and pump it through the system. One question remains: Why do you bypass the hot water tank when winterizing? Do you not want antifreeze in the hot water tank? What keeps the hot water tank from freezing if it doesn't have antifreeze in it? Sorry guys. I'm a little slow. Please FROG me.
Lon is offline   Reply With Quote
Old 02-01-2015, 09:35 PM   #25
SKnight's Avatar
The valve isn't the cause, the vent is plumbed over an inch down from the top of the tank. It's a poor design. I fixed mine, works well and I don't siphon a drop anymore.
Old 02-02-2015, 07:20 AM   #26
caper's Avatar
You drain the water from the HW tank. The bypass valves allow you to put the pink stuff in the water lines with out putting it into the HW heater. The small amount of water left in the tank will not hurt because it has room to expand and it freezes.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 02-02-2015, 09:20 AM   #27
Ret E-9 Anchor-clanker
donanddona's Avatar
Normally (AFTER the water in the water heater has cooled) we remove the anode (drain) plug to inspect and replace if necessary. Their are a couple of ways to flush the WH tank out. 1) use a wand and water jet it clean. 2) after removing the drain plug, turn on the city water or your FW pump and let her flow for 3-4-5 minutes. After flushing just let it drain out dry. It's one of the final steps when winterizing. For snowbird full timers like me, we should do this once a year anyway.
donanddona is offline   Reply With Quote
Old 02-02-2015, 09:43 AM   #28
Flybob's Avatar
You can put anitfreeze in the HW tank, but there is no need to waste 6 Gallons of antifreeze, when you can just open the drain plug and empty most of the water out so freezing will not harm it. Don't forget your outside shower. Out of sight and out of mind, and plastic faucet.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 02-02-2015, 09:45 AM   #29
'MY' 'Dealer' redid the breather tube from the rubber to house piping and (said) reran it to where it would not cause the siphoning action..... Did not work/help/ or change a thing. How Exactly did you redo yours? I will not take it back to 'them' and fix it myself if I have a better idea on what to do than what they did.
Thank-you
Brother Les
Old 02-02-2015, 09:51 AM   #30
(Dry Huunday)
DreiHunde's Avatar
Originally Posted by RPAspey View Post
Make yourself one of these and keep using the blue jugs. And you'll have a spare pump. I've used mine to also wash the dogs outside (I don't have an outside sprayer)
Great job on that!!!
Beau & Sue
FurKid Express
2015 Coachmen Catalina 303RLS
DreiHunde is online now   Reply With Quote
tank, water, water tank
