Old 02-02-2015, 01:12 PM   #31
SKnight's Avatar
Originally Posted by Brother Les View Post
'MY' 'Dealer' redid the breather tube from the rubber to house piping and (said) reran it to where it would not cause the siphoning action..... Did not work/help/ or change a thing. How Exactly did you redo yours? I will not take it back to 'them' and fix it myself if I have a better idea on what to do than what they did.
Thank-you
Yeah, my dealer showed the same competence.
I took the factory breather, added a tee valve on the end, then attached a hose on the other end of the tee, ran that up and over the LP tank with the top of the loop a couple a foot or so higher than the top of the fresh tank. I then let a couple of feet of hose hang down next to the tank.
With the tee valve closed I fill as normal until water is coming out the vent at the LP tank. At that point I open the tee valve to drain the high end of the hose, then close it. That breaks the actual siphon effect caused by the high loop. The hose will still have water in it, since the vent is below the high water line, after a day or two of use I'll open the tee one last time to let it work normally.
So I get to use much more of my tank and I don't lose any water while traveling.
Back to your normally scheduled thread.
Old 02-06-2015, 11:14 AM   #32
Too Tall's Avatar
I can't believe they removed the external potable water fill tube. I didn't know that. I guess they are only putting them on the small trailers like my 21'.
Regarding the Federal parks, In previous years, I had a 40 gallon tank that came out out another RV. I rigged up a pump so I could fill my tank all in one shot with it and always kept it full when I knew I would need more water. There's nothing like running out of water when you're all soaped up in the shower. (try to avoid the visual on this)
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
Too Tall is offline   Reply With Quote
tank, water, water tank
