Old 02-08-2014, 10:08 AM   #1
jonrjen's Avatar
Ready to de-winterize the 5th wheel...
OK, this is a first for me after almost 3 decades of RVing I need to de-winterize the Wildcat and flush out all of that pretty pink fluid from the system.
And words of advice, secrets, tricks or knowledge you can share with me? Is it as simple as hooking up the water with a pressure regulator, turn on the water, open all of the faucets and let it run until it is clear?
Is it best to open the faucets one at a time or do them all at the same time?
Our Wildcat has the tankless hot water heater, I assume I just need to run the hot water line open also until the water runs clear with the tankless heater turned off?
Is pink RV antifreeze nature friendly as in can I let it drain out of the holding tanks into the driveway? I am assuming that it is since it was placed in drinking water lines used for human consumption and use.
2013 Ford F350 FX4 4x4 PSD
2013 Wildcat 353LS
2015 Day/Nights Camped 5
2014 Day/Nights Camped 29
jonrjen is offline   Reply With Quote
Old 02-08-2014, 10:44 AM   #2
jtstromsburg's Avatar
I usually drain most out of the low point drains. Then, open the furthest faucet from the hookups and run till clear. Sane at each water source. Then, you should sanitize the system so it's ready for the year. Do tankless wh still have bypass valves?
Sent by me
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 02-08-2014, 12:15 PM   #3
jonrjen's Avatar
Sent by me
I' don't know, but I will be looking for an answer or be digging in deep to find out.
2013 Wildcat 353LS
Old 02-08-2014, 12:45 PM   #4
jevanb's Avatar
no they do not, and I should know since I have worked on mine for hrs trying to get the bugs out of it. All good now. when I flush I just hook up water and let water run a long time with all the faucets open, then I put bleach in fresh tank, let sit in pipes for a day and do it all over again. I drain my tanks when I flush them on to the driveway but I live in the woods and have no neighbors, and dont mind the small poop left in it that hits the driveway
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
Old 02-08-2014, 02:13 PM   #5
jonrjen's Avatar
I appreciate your feedback. We are in the city limits but not by much. Our lot is 3 acres so I feel pretty good draining the antifreeze out to the driveway since the trailer has never been used....yet!!!
2013 Wildcat 353LS
Old 02-09-2014, 05:10 AM   #6
Oakman's Avatar
When you have the water running don’t forget to flush the toilet, open the outside shower faucets and if your trailer is pre-plumbed for a washer open those faucets too.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 02-09-2014, 06:23 AM   #7
jonrjen's Avatar
I am also going to remove the faucet water save disc from each location to allow better flow when doing the de-winterization
Thank you all for taking the time to teach this old dog how to take on something new.
2013 Wildcat 353LS
5th wheel, wheel, winter, winterize
