04-25-2019, 06:17 PM
Reinstall anode rod/suburban hot water
Replaced anode rod. Cleaned threads of tank which are still a little rusty.Put tape on rod and used a 1 an 1/2 inch socket. It's a tight fit. HOW FAR do I need to screw it. It won't screw in all the way. Thanks!
04-25-2019, 06:28 PM
Kanadian Kamper
If you noticed when you removed it (did you remove it or have someone do it?)
there are always some threads showing. If everything’s in place and threaded snug to tight, there will be threads showing but no leaks when in use.
Ken and Terry
04-25-2019, 07:03 PM
Ken, I took the rod out after season and winterizing. There are threads showing and it is snug. Thanks for the info.
04-25-2019, 07:08 PM
You're probably good. Fill it with water, and see if it leaks. If not, hooty hoot!
FROG AR-0019-242
04-25-2019, 07:53 PM
Mine only goes in about 1/2 the threads. It doesn’t have to be that tight.
There is a spec if you really want to know.
Do not over tighten. That material is pretty thin.
You can get a cheap tap on Amazon for $10 to clean the threads
Or an ok one for $20
Either one will work
2017 Puma 297RLSS
04-25-2019, 09:30 PM
Thanks I'll let ya know. We're park ATTENDANTS for 110 days at Robert W Craig campground in WV!!! Tomorrow is setup for camp hosts and park attendant's.
04-25-2019, 09:32 PM
Attachment 202850
Attachment 202851
I got a stiff brush and cleaned the threads. Thanks for info on tap.
04-25-2019, 09:39 PM
Just as confused as you
If you have a small leak just tighten it a little more. You said you used a 1-1/2" socket, the actual size is 1-1/16".
Richard & Jill
04-26-2019, 09:37 AM
Sorry Scrapper I meant 1-1/16 socket. Just excited about heading to camp.
04-26-2019, 10:29 AM
The anode has tapered pipe threads. It just screws in enough for the taper to seal. The Teflon tape or other makes up the minute difference that could leak.
You will have exposed threads visible.
2011 Flagstaff 831 RLBSS
04-26-2019, 02:55 PM
the anode is 1 1/16 hex and the threads are pipe threads meaning it's a tapered thread smaller a at from and getting larger towards the hex. Put some teflon tape on the thread and tighten until snug. should leave 3-4 threads showing. Check for leak and gently tighten if leaking
04-26-2019, 03:06 PM
For tapered pipe threads I was taught that you wrap it with Teflon tape, or coat it with pipe dope, snug it up then go 1/6th of a turn. If your threads are in good condition it should seal.
2016 Salem 27RKSS
04-26-2019, 04:27 PM
pipe dope is definately another good option
04-26-2019, 04:32 PM
Site Team Note:
For a complete list of nominations of proper anode rod thread sealants, see this thread ==> http://www.forestriverforums.com/for...od-180601.html.
Site Team Note
04-26-2019, 05:56 PM
Originally Posted by Mr. Dan
THAT IS FUNNY MR. DAN
thank you for that
2017 Puma 297RLSS
04-27-2019, 06:35 AM
Only Until It’s Tight Enough
NPT threads are tapered and should never be “buried” into a fitting. You tighten whatever it is you are tightening until it is “tight enough” to not leak. If you go too far, you can split the hub of whatever fitting you are screwing into. You can also cause the fitting to expand enough to where the next time you thread something into it, you won’t be able to get it tight enough to where it won’t leak. There are specific torque measurement ranges for the various sizes of NPT threads, but “tight enough” is what you are looking for. As a plumber, I have a built-in torque range indicator from my hands to my shoulders that tells me when it is tight enough and it very rarely fails me.
DON’T OVER-TIGHTEN IT
Bruce
