Old 06-24-2013, 01:16 PM   #1
YKX
Removing Bathtub
Is there a special way to remove the bathtub? I have a cracked water line behind it and want to fix asap. There is the vanity right beside it as well. I have a 5th wheel 2009 Grey Wolf 28ft one slide. Bathroom is small. I am hoping NOT to remove the vanity but that might have to go too. Thanks
YKX
YKX is offline   Reply With Quote
Old 06-24-2013, 04:19 PM   #2
YKX
Its a 2009 Forest River Cherokee Grey Wolf 235BH 5th wheel
Old 06-24-2013, 04:56 PM   #3
MOD Guy's Avatar
A picture of how the bathtub mees the vanity wold help in answering your question. You probably have a wall surround above the tub that will have to be removed. It should be covering a flange that is screwed to the wall holding the tub in place. You need access from below or from an adjoining wall to disconnect the drain.
Chuck Roder & Family
'07 Surveyor SV-235RS & '16 Chevy Silverado 2500HD (Gas) Crew Cab
High Springs, FL.
MOD Guy is offline   Reply With Quote
Old 06-24-2013, 06:20 PM   #4
You should be able to remove the faucets in the shower and down below the floor from the basement and not have to remove the tub. Sure worth a try.
Old 06-25-2013, 02:27 PM   #5
YKX
update: got the tub out WITHOUT removing the taps. There was only a few screws and metal brackets around the tub surround. The tub is really not a big thing, was thinking of making the tub bench (what goes under the bathtub) stronger. I am 6 feet, 250lbs. Not to sure if i would ever use it, but might as well just in case. Had to cut the caulking but all in all, it was a easy project. FOUND the leak in the pipe. It did have a crack, so i am going to replace who pipe with updated pex piping. Thanks again for your responses. Love the site too!
