Old 06-06-2016, 12:42 PM   #11
Telstar's Avatar
Thats exactly how my Cardinsl is plummed. The nackflow prventor on mine is accessable behind the shower valve. I replaced my sprayer with the rotating one available at Camping World, works much better.
Gary and Donna
2005 Cardinal 33TS-LX
Trail Air pin box
Center Point suspension
2005 F-350 6.0 psd CC SRW
PullRite Super 5th
Telstar is offline   Reply With Quote
Old 06-06-2016, 01:28 PM   #12
bubbles's Avatar
Originally Posted by B and B View Post
It is against code RVIA and just about any municipality
From RVIA
Plumbing Systems as specified in NFPA 1192 Standard for RVs.
Only listed plumbing devices, fixtures and appliances that have been labeled by nationally recognized testing agencies are allowed.
Water distribution systems are sized to provide adequate flow rate and designed to prevent backflow contamination.
Fixtures with traps and vents must be provided to protect against siphonage and back pressure.
Vents to release gases from any waste holding tank must be provided.
Check Valve is a modification to a code requirement. A step but not replacement for the Vacuum Breaker.
Never said there was no code for the install of these systems. It is in fact referenced on the document I posted. I just said that because of the routing of the tubing in my RV cleanout, in my opinion, the backflow preventer is an over kill. It's just an opinion and everyone has one of those. The cleanout is only used when emptying the tank and it's empty when finished and I cannot see how any backflow from an empty tank can get to the input spigot where pressure was previously applied. That's all.
Old 06-06-2016, 09:15 PM   #13
Canadian Member
itat's Avatar
Suffice to say a backflow preventer is required by code. If it wasn't, FR wouldn't install it. There is a direct connection between the black tank and the campground's potable water supply system so the water supply system has to be protected from contamination.
I use an external brass one like the picture B & B posted because the original owner of my TT removed the factory version.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
Old 06-06-2016, 09:31 PM   #14
B and B's Avatar
This does happen in real life.
Google Walkerton Ontario...
7 dead due to Ecoli...same as missing back flow preventer can cause.
When this is removed it creates a hazard for others. If you choose to do something like remove your LPG protectors that is more or less a hazard for you unless the trailer blows up and sends shards of metal at your neighbours.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
black, roo
