Old 07-31-2011, 04:13 PM   #1
Herk7769's Avatar
Repairing a Thetford Aqua Magic V
The symptom was almost no water pressure coming out of the flush nozzle when flushing the toilet.
Not knowing what was wrong, I bought Thetford Kit 31738 Aqua-Magic Nozzle Kit (glad I did as you will see later); Thetford Kit 31705 Aqua-Magic V Water Module Kit; and on a lark the Thetford kit 19289 Aqua-Magic/Aria Classic/Aurora/and Style "Water Saver" hand spray wand.
After disassembling the toilet and examining the Water Module; the reason for the pressure loss turned out to be a small calcium nugget jammed into the exit port of the Water Module flush valve. (see Photos)
I did notice that the new Valve's exit port was MUCH larger than my old one and the nugget would not have clogged it.
I drilled the old valve open to closer match the new valve port and reinstalled the old one.
I DID replace the nozzle however as it was TOTALLY redesigned MUCH better. More in post #2
Name:	Camper Bidet 022.jpg
ID:	7130   Click image for larger version
Name:	Camper Bidet 023.jpg
ID:	7131   Click image for larger version
Name:	Camper Bidet 024.jpg
ID:	7132   Click image for larger version
Name:	Camper Bidet 026.jpg
ID:	7133   Click image for larger version
Name:	Camper Bidet 025.jpg
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 07-31-2011, 04:16 PM   #2
Herk7769's Avatar
Why Change the nozzle?
The lower nozzle was the old one. It was flimsey, overly long, and kinked.
It was held in place with an O ring and friction.
It was a water leak waiting to happen.
The new one is Heavy Vinyl tubing and just the right length.
Name:	Camper Bidet 028.jpg
ID:	7135   Click image for larger version
Name:	Camper Bidet 029.jpg
ID:	7136   Click image for larger version
Name:	Camper Bidet 030.jpg
Old 07-31-2011, 04:17 PM   #3
Herk7769's Avatar
I decided to add a shutoff valve while I had the Thetford off the base.
I used a Gatorbite PEX valve.
Name:	Camper Bidet 008.jpg
ID:	7138   Click image for larger version
Name:	Camper Bidet 009.jpg
ID:	7139   Click image for larger version
Name:	Camper Bidet 017.jpg
Old 07-31-2011, 05:05 PM   #4
bsmall's Avatar
Good job Herk and great pics...
Bill
2020 GMC Duramax-3500HD 4x4 CrewCab
B&W Companion 25K Fifth Wheel Hitch
2010 Wildcat 28RKBS (West Coast Model)
56 Gallon Titan Tank
bsmall is offline   Reply With Quote
Old 07-31-2011, 05:15 PM   #5
Herk7769's Avatar
The problem with the wand surfaces
I installed the hand wand as per the directions to the flush valve.
After snipping off the end of the built in barb, I hooked up the hose.
While drilling out the nozzle opening to the dimension of the new valve will prevent future build ups of calcium and the flush is very strong, it takes so much pressure away from the wand; it is almost useless.
Frustrated, it was off to the home store for parts to make a tap directly off the feed pipe. I needed "another" shutoff valve in case the hand wand started to leak. (there would be no way to isolate it and we would then lose the toilet.)
It works awesome. Strong flush and wand spray even on the OEM water pump.
Name:	Camper Bidet 033.jpg
ID:	7141   Click image for larger version
Name:	Camper Bidet 035.jpg
ID:	7142   Click image for larger version
Name:	Camper Bidet 038.jpg
Old 07-31-2011, 05:19 PM   #6
Herk7769's Avatar
Oh, don't forget to dose your black tank with deodorant (double dose) before you pull the toilet. You will be happy you did!
Old 07-31-2011, 05:45 PM   #7
bsmall's Avatar
Glad it all worked out for you Herk, I think your'e going to be very happy with it...
Bill
Old 08-04-2011, 07:41 AM   #8
Zhanna's Avatar
Is any of this possible without pulling the toilet out?
Zhanna is offline   Reply With Quote
Old 08-04-2011, 10:08 AM   #9
Herk7769's Avatar
With the Aqua Magic V there are only 2 bolts that hold the toilet to the floor. There was not enough room in my installation to get tools behind the toilet without removal. It really made the process easier to have it out. Just put a rag in the hole to make sure nothing falls into the hole.
The water spray hose kit came with two types of toilet to floor seals and in my camper the one with the square sides was used.
Name:	Camper Bidet 010.jpg
Old 08-07-2013, 04:20 PM   #10
Low Toilet Water Pressure
I was having a problem with low water pressure on my toilet. After reading the first solution I got to thinking, what if I had something blocking my line? What could I do to unblock without a to much disassembly. Then it came to me why not blow out my line from the toilet flow back. So I rigged up a flex line on the end of my air hose, bleed off any water in my line and then blew air from the toilet line outlet which cleared my problem.
Next I will sanitize and flush my cold water line. Everything works great.
string1 is offline   Reply With Quote
Old 08-09-2015, 12:25 AM   #11
Herk did you get the Gatorbite valve at HD. I have to replace the fill valve Thetford 31705, due to the valve desiding when/when not to, shut off. Going to install a cutoff while im at it.
maxjr758 is offline   Reply With Quote
Old 08-11-2015, 07:54 PM   #12
Herk7769's Avatar
Either there or Lowes...
Old 08-11-2015, 08:53 PM   #13
Thanks, I dont know why they dont have cut off valves, in the first place! Guess its all bout that $$$$$$
Old 05-27-2017, 01:06 PM   #14
Frank DeFeo's Avatar
Thanks Herk. Both you and Ken are on the same path, blockage at valve. I'll check it out.
Frank DeFeo is offline   Reply With Quote
Old 07-14-2017, 02:50 PM   #15
Aqua Magic V
All,
FYI, I just purchased an Aqua Magic V from Amazon. The unit came with a solid plastic hose from the water valve to the toilet bowl inlet. It may be only the replacement units have this and not the manufactured RV units. Who knows. Just thought I'd let everyone know.
Jim
jpaskell is offline   Reply With Quote
