10-29-2019, 10:16 AM
2014 Heritage Glen
Repairing Polyethylene Fresh Water Tank
My Forest River 35' Heritage Glen developed a water leak under the TT. I have, at times, filled the 30 gallon tank before I traveled. I found the leak was coming from the polyethylene fresh water tank itself. Further investigation showed the metal bracket that supported the rear of the tank was bent and the tank had dropped down about an inch in the front. When this happened, the tank slid forward and the tank rubbed up against another front bracket that caused a small crack in the front, on each side of the tank. I plan to repair the tank using the polyethylene/heat method. I have a heat gun and have ordered the polyethylene strips to repair the cracks. In the meantime, I read where a plastic milk jug is made of the same polyethylene plastic and the jugs have HDPE (High Density Polyethylene) stamped on them. Is it OK to use the plastic from the jug to repair the cracks? I also plan to reinforce the supports around the tank to fully provide the proper bracing for the tank which it did not have. Needless to say, the 30 gallon tank will be empty from now on anytime the trailer is towed!
10-29-2019, 10:43 AM
I have not tried to repair a crack in a tank and do not know about milk jugs. However I have repaired the supports for potable water tanks and if done correctly there is no reason for not caring water in your tank other then the added weight.
Retired Navy
2016 Flagstaff 26 FKWS
10-29-2019, 11:11 AM
2014 Heritage Glen
Thanks, Sea Dog I've seen on other post where 2" X 2" X 1/4" angle iron was used to reinforce the support with good results.
10-29-2019, 11:36 AM
If you have the 'proper' stuff on order, I would not try to patch with a milk jug that you don't know the composition of the material. Why not just wait for the right stuff to arrive?
Days Camped ☼ '19=118 ☼ '20=116 ☼ '21=123 ☼ '22=134 ☼ '23=118☼ '24=86
10-29-2019, 12:00 PM
You could try this if you have room to get the heat gun near the crack.
https://www.tapplastics.com/product/...d_adhesive/435
You can avoid reality, but you cannot avoid the consequences of avoiding reality – Ayn Rand
10-29-2019, 04:13 PM
My 2 cents...perhaps all it's worth.
If you attempt repair, expect disappointment. You might get lucky, but more likely not. A plastic weld might work...as might the TapPlastics product. Don't mess with a milk jug. You'll probably only get one chance at a "weld." And the work involved with doing the job, putting it all back together, adding more bracing, and then discovering failure is not worth a milk jug experiment. I understand that there are pros who do plastic welds.
After many attempts to patch or seal my tank, I surrendered and installed a new one. The crack just kept growing, and no adhesive really stuck. My replacement tank cost about $95 plus about $20 for shipping...from Forest River. I was thrilled with the price. Yours might be $200 + $35 shipping.
If you intend to replace, first verify that tank removal and replacement is reasonably possible. Inspect carefully and measure clearances. In my case, the tank sits somewhat over the torsion axle. And the cable roof lift mechanism passes below the tank but over the axle. If I had not lifted the camper, I would have had to drop the axle to get it out. Removing the cable lift is, at least with my skills, out of the question. Since I was lifted, I had just barely enough room to remove and replace. Dropping the axle would have been very hard. As it was, the job was easy.
Above all, repaired or replaced, substantially reinforce your tank supports. If it's tucked up out of harm's way, angle iron or U-channel will work wonders. But it's likely you'll need to be inventive installing the bracing...and careful to avoid puncturing the tank or wiring or propane lines, etc. You may need to fabricate hanger straps for your additional bracing.
The good news (if you can call it that) is that your tank is empty and the supports require attention anyway. Plan your attack and use the opportunity to move the tank out of the way to attach mounts for your additional bracing. Any fasteners that might touch the tank should be padded to prevent them from wearing thru the tank. Elevator bolts might be handy here: https://www.amazon.com/Hard-Find-Fas...56056391&psc=1 My tank was shouldered with wood blocking to keep it from chaffing on steel, but every one is different.
In my PUP, I got very lucky. There are "looms" for propane lines, wiring, etc. on either side of the frame, so a piece of 1/2" galvanized water pipe, a pipe clamp, two clevis pins, a square of plywood and a rubber door mat did the trick. My tank's only 20 gallons, so the support isn't doing that much work, but before I installed it, my tank was sagging about 4". Now no sag at all.
I boondock exclusively so I always travel with a full fresh tank, and I normally travel extremely rough gravel roads and sometimes no roads. The support made all the difference. You need to find a way to achieve the same goal if you intend to boondock or travel wet to a location that doesn't have potable water.
The 2nd pic is my idea of camping.
Jim & Renee
2020 Jayco Jay Feather X-213
Every weekend boondocking in the National Forests or at Lake Vallecito.
10-29-2019, 04:40 PM
imo, fix your supports to hold the correct (over) weight, then get a new tank.
The plastic water jug will not be compatible.
Brother Les
10-29-2019, 05:40 PM
Rwgrigg, I think your approach is good, but you may need a plastic welding tool to make this work. You may be able to gather enough heat from a heat gun, but the wind from the gun may make handling the liquefied plastic impossible. Prior to retirement, I have installed miles of HDPE electrical conduit and I promise you there is no adhesive made that can chemically weld the two sides together. Those that are advertised are really a type of epoxy that only sticks to the surface once it is roughed up enough to provide some grip surface area and in a wet environment, they always fail. The only appropriate method to join HDPE conduit is via thermal fusion. This requires getting the plastic very hot ( I think it was somewhere around 350 to 400 degrees F) it must liquefy before the 2 edges are mated together. If you can do this, the crack should be repairable and the repair will be permanent. Before you return the tank to the underbelly, be sure to have some substantial bracing ready to install. You also want to provide some padding between any bracing and the tank since it seems to fit somewhat loosely and is subject to moving about ... enough to rub.
If you end up not being able to seal the leak, then I suppose replacement may be your only option. Again I would prepare additional bracing and padding before I install it. Good Luck with the project! ... Jim
Jim (Swampy), Susie, Jimmy & The Chihuahua Crew
2008 Chevy Silverado LS, 4.3L, V6, 2WD, 3.23:1
2014 287 BHBE; 1981 JayRaven: Predator 3500i - Call Home Pearl River, Louisiana. on The Honey Island Swamp
https://www.forestriverforums.com/at...pic81807_1.gif
10-29-2019, 07:31 PM
Also before welding the crack drill a small 1/16 hole at the start of the the crack at each end of the crack. This will stop the crack from spreading after welding it.
10-29-2019, 07:53 PM
You might want to get a few small pieces of poly to practice on before making the tank repair. Like all fusion work (Soldering, brazing, welding, etc.) experience is your friend.
10-29-2019, 10:40 PM
These products are basically an expensive 2-part epoxy. In my experience, they all fail because nothing actually sticks to polyethylene. You can slather it on like paint, but it will not bond to the PE and ultimately it will pop off. As I stated in an earlier post, the only sure fire way to get polyethylene to stick together is via thermal fusion where you melt the PE and let the molecules of each part merge together. Normally the resultant joint is stronger than the original. Using the fusion method of joining PE conduits, I have made horizontal pulls in a bore hole of over 1000 feet. Dresser couplings usually failed in under 100 feet, and Bonduit and several other brands I have tried usually came apart at less than 100 feet. You neede to read the product specifications as well as the application data.... Swampy
10-30-2019, 08:32 AM
I agree with getting a true plastic welder (A decent one and not one from Hazard Fraught).
Trying to use a heat gun, even if you have a plastic welding tip for it, is a crapshoot. The wall of a FW tank is thin, less than 1/8" usually, and you stand a good chance of blowing a hole clear through it. A good tool that you have full control of the heat is important. So is practice. Buy some cheap cutting boards and poly bins at Walmart and practice on those first.
Its a lot harder to weld thin material than thick, it's way less forgiving. Also doing it upside down is tough. It's a lot easier if you can get the tank out and are welding down on it, such as on a bench.
They have cutting boards at Wallyworld that are compatible and are about 3/8" thick. I have cut those into squares larger than a crack if its not on an edge and welded them over it . Stronger and easier than trying to stitch the crack closed with the thin wall.
