Old 11-04-2017, 06:41 PM   #1
Replacing 2109s DOM 300 Toilet with 310
Greetings All....I would like to replace the plastic Dometic 300 toilet in my Rockwood 2109s Mini Lite with a Dometic 310. Has anyone done this, and were any modifications needed? According to the specs the 300 requires 10" from the middle of the flange to the wall, while the current 300 only requires 8.5". I'm hoping the 1.5" won't be a deal breaker. Thanks for any input!!
GJCrawford is offline   Reply With Quote
Old 11-04-2017, 06:58 PM   #2
Have you measured it? That will tell you if the 1.5" is a deal breaker. Someone here didn't have room, but I can't recall which model TT they had.
(Sometimes you can rotate the toilet 45 deg and it will fit; if the flange will let you.)
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
2109s, 300, 310
