Old 06-04-2016, 07:35 PM   #1
replacing a waste water valve
I need information on replacing the black tank waste valve on my 295 crusader. the valve is hidden by the material under the trailer. There is no access panel to get to the valve. What is the best way to get to the valve ?
jeffscuda is offline   Reply With Quote
Old 06-04-2016, 07:53 PM   #2
Head Rambler
If you know exactly where the valve is, you can cut an 'access' opening in the coroplast bottom and replace it and seal it with gorilla tape. If you don't know exactly where the valve is located you can remove the trim that holds the coroplast in place in the general location of the valve and drop it down. Once you locate it, you can either drop it enough to change the valve or cut the aforementioned access opening.
Gotta go campin!
Old 06-04-2016, 07:55 PM   #3
Left Coast
Use a box knife and cut a 3 sided access panel, then use Gorilla tape to seal up.......leave the attached side toward front of trailer
water
