Old 12-14-2015, 04:09 PM   #1
Oakman's Avatar
Replacing old toilet with a new one
I'm going to replace the Dometic model 310 toilet with a new 310 model. Is this going to be an easy swap like it seems it should, or can I count on running into problems?
The trailer is in winter storage and suddenly for some unknown reason it quit holding antifreeze in the bowl. I feel replacing the entire toilet will be quicker and easier than trying to replace the flapper and gaskets on the old one.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 12-14-2015, 06:30 PM   #2
bubbles's Avatar
Just sounds like the seal (rubber gasket) needs replaced. It only takes a couple minutes due to it coming out and going in from the bowl. It just fits into a flange around the top perimeter of the opening. If you are dead set on changing out the whole thing it should take no more than 15 minutes. 2 nuts on the mounting studs (just like at home) and she comes right up. A wax donut is not used, a foam rubber floor seal is used and that comes with it. The new one comes with complete easy to understand instructions.
Old 12-14-2015, 08:18 PM   #3
dometic toilet
I agree with bubbles. I would try the gasket first, a lot cheaper and may very well solve your problem. Can't hurt to try it.
jpaskell is offline   Reply With Quote
Old 12-14-2015, 09:28 PM   #4
I Feel at Home When I'm on the Throne
IF your going to replace it go ahead and go up to the Model 320. A full sized man's toilet. You can then go to Lowes and buy any elongated toilet seat, just like at home. I like the seats that don't slam shut, DW likes that also.
Just make sure you get the 18" tall and not 14" unless you like your knees in your chest and take into account that it is elongated and will stick out a little more. I upgraded in our 33IK and it fits just fine.
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
Old 12-15-2015, 08:28 AM   #5
ryand's Avatar
I replaced a Thetford plastic toilet with a 310 last year. It was pretty simple and no modifications were needed to the waterline.
2011 Coachmen Catalina 28DDS
2015 Ram Bighorn 2500 6.4L
http://www.ryandethrow.wordpress.com
Nights Camped 2016: 32
ryand is offline   Reply With Quote
Old 12-15-2015, 01:38 PM   #6
I've always replaced the toilet in every used motorhome I ever bought. A $200 toilet doesn't seem much extra expense in a class C. I always replace before repairing when it comes to toilets. Everything else is normally repair before replace.
bobm253 is offline   Reply With Quote
Old 12-15-2015, 04:08 PM   #7
7 Year Class A RV'er
Just be sure to check the dimension from the wall to the center of the outlet. That's what prevented me swapping the toilet in our old RV - not enough space.
2015 Legacy SR340 360RB
Old 12-16-2015, 12:38 PM   #8
Oakman's Avatar
Well even though I don't like the thought of doing it, I've decided to replace the flush seal this spring. I will be wearing gloves but even so, I don't like the thought of putting my hand in that area of the toilet. Perhaps it's because I know what I put through that opening in the mornings.
Bob and Joyce
ATU Local 788
Old 12-17-2015, 08:15 PM   #9
OLYGOLFER's Avatar
Besure to check the fitting configurations...ie 90 deg elbow etc.
I replace an older model with a new nice and larger seating china bowel, but it took a lot of research and work to get the new one fitted apprx 1.5 inches off the wall and with elbow vs straight tied in !
OLYGOLFER is offline   Reply With Quote
Old 12-17-2015, 08:37 PM   #10
How to replace gasket..
https://youtu.be/vi3TRivsNlQ
2016 Siverback 33IK
