Old 07-01-2012, 09:21 AM   #1
Replacing Plumbing on my 2004 Surveyor
Where is a goodplace to buy replacement plumbing for my Surveyor?
BostonMike is offline   Reply With Quote
Old 07-01-2012, 10:17 AM   #2
Hello, and to the forums. Now, as for replacing your plumbing, what are we talking about? Are you talking about fixtures? Just measure the distance between the handles, and Lowe's, Home Depot, local hardware, etc. will have some the same size. You will need to know how far between the hot and cold handles. If you are talking pipe, if it is gray, it is Quest, and wil be hard to find, and I wouldn't put it back. If it is red for hot, and blue for cold, it is Pex, and can be found at places mentioned above. Takes a crimp tool, and crimp rings to put in, and a special cutter helps too. Good luck with your project.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 07-01-2012, 10:33 AM   #3
Broadway Joe's Avatar
Please specify what you are referring to as "Plumbing". Are you looking for toilets, shutoff valves, or water lines, etc.
Broadway Joe is offline   Reply With Quote
Old 07-09-2012, 11:22 PM   #4
Location: 2283 Lost Creek Road Sinking Spring, PA 19608
Although, you did not clear your needs. Moreover you can buy any plumbing items in your area and also from online. For example : There is a shop in my area and I always buy from there.
San Diego Plumbing, Heating and Air Conditioning Specialists |Anderson Plumbing Heating and Air Ľ San Diego Plumbing, Heating and Air Conditioning Specialists
Dean Haviland is offline   Reply With Quote
