Old 04-08-2019, 11:43 AM   #1
pokey's Avatar
Replacing toilet seals
Hello all, I have a Dometic 210 toilet in my 5th wheel and need to replace the seals. I ordered the seals from Camping World after verifying the correct part number from Dometic. The seals look much different than what's installed? The lower part (where the lower seal goes) is a very hard I believe to be rubber and the seal in the kit is a thick pliable black round seal with notch. According to researching the seals have been changed from their originals. Does the new black seal totally replace this lower hard rubber like piece and then the grey seal on top? The new seals also have notches where mine shows none but say's if applicable. The new seal kit # is 385311462 per Dometic to be correct. Thanks for any info anyone can provide!
Name:	Toilet seals.jpg
Pokey
Permanent RV'er
2006 Cardinal 29LE
Why do today what you can put off until tomorrow.
Retirement life........
pokey is offline   Reply With Quote
Old 04-09-2019, 05:42 PM   #2
pokey's Avatar
Update on seals
Correct seals toilet repaired.
Pokey
Permanent RV'er
2006 Cardinal 29LE
seal
