Old 07-11-2014, 02:54 PM   #1
Replacing Water Fileter 21FBRS
I have been paranoid about the Water filter on my TT since I started reading about them coming off in these Forums. Next Wednesday, DW and I are planning to take off for a 5 day weekend that is absolutely needed. I started removing the filter, but had issues getting it unscrewed. I believe I have damaged the male end connection. Should I cut the fitting off and replace with another clamp? or would be better to remove the clamp at the T and work from there.
I consider myself pretty handy and have done many plumbing project in my home, but never worked with this Pex Stuff. i about to find a plumber as i do not want water leaking in my camper
thanks in advance
2015 Ram 2500 4x4 6.4l with 2015 Sandpiper 25RLS
Wife, myself and 2 furry kids
Mountndream is offline   Reply With Quote
Old 07-11-2014, 09:43 PM   #2
Slympicins's Avatar
Buy a stick of PEX tubing and cut it with a PVC cutter (to make clean cuts). Buy two connectors and use them on each end where you removed the filter housing. Tip...take a cup of hot water to heat the ends of the PEX tubing when using the connectors. It will make life a lo easier.
Before
Name:	ImageUploadedByForest River Forums1405132813.883073.jpg
After
Name:	ImageUploadedByForest River Forums1405132885.781576.jpg
I keep extra connectors and PEX pipe in the TT to aid those who have the same issue while out camping like I did. It will cost around $10.00 to remove the filter, but could cost major money to repair the damage for a filter malfunction.
Chuck and Joanne
2014 Flagstaff Super Lite Classic 27RLWS Emerald
2013 Dodge 2500 4x4 Laramie Crew
Equal-i-zer 1200/12,000 4-point WDH
Slympicins is offline   Reply With Quote
Old 07-12-2014, 12:36 PM   #3
Wow, that was easy. I am never touching copper pipe again.
Thanks for everyone's help
Old 07-12-2014, 07:56 PM   #4
Slympicins's Avatar
Glad to help when ever I can.
Chuck and Joanne
Old 07-17-2014, 07:59 PM   #5
Here is what I ended up with
Old 07-17-2014, 08:01 PM   #6
Name:	ImageUploadedByForest River Forums1405645249.621136.jpg
water
