Old 03-01-2016, 12:38 PM   #1
Replacing whole RV water filter
We have a new Columbus fifth wheel. I am trying to install the water filter and can't for the life of me loosen the canister. I dont
want to break the plastic canister and I am bending the wall it is mounted to. Eventually I am replacing the filter system but for now I just want to get this filter in there. Any tips or tricks? Thanks.
rblake39 is offline   Reply With Quote
Old 03-01-2016, 12:44 PM   #2
Is there water in there now? Youroo!!
Old 03-01-2016, 12:46 PM   #3
Yes. Do I have to drain it?
Old 03-01-2016, 12:46 PM   #4
If the answer is Yes,open a fixture to releave All the Pressure! Youroo!!
Old 03-01-2016, 12:47 PM   #5
Ford Idaho's Avatar
If you are using enough force to tweak the wall stop!
Just get an inline filter and us it.
Old 03-01-2016, 01:26 PM   #6
It's a pretty flimsy wall. Doesn't take much. Guess I'll get the new filter system sooner than later.
Old 03-01-2016, 01:34 PM   #7
Ford Idaho's Avatar
Good, sooner the better for you and your unit...
I was concerned you may crack the head or the canister and not notice it until it was to late.
Old 03-01-2016, 01:59 PM   #8
Pickin' & Campin'
If it is a factory installed filter...
Try pushing upwards (towards the mounting head) on the canister before turning.
Most folks don't realize the head has teeth and the canister has tabs.
Pushing up on the canister releases the contact of the teeth/tabs so it can be loosened.
Conversely, when installing, twist until aligned and pull down on the canister slightly to lock the teeth/tabs in place.
A small dab of silicone grease around the o-ring seal makes the process a whole lot easier.
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 03-01-2016, 02:03 PM   #9
x2.. Open the faucets and filter should come right off.
2015 Shamrock 231KSS, Oyster shell
2016 Chev Silverado LT Z71 Ext. Cab, 4x4, 5.3L V/8
Reese Straight Line WDH, 2000W Honda Gen.
2 Old Town kayaks & 2 Boston Terriers - Zoey/Gonzo
Lar & Ruth
55 nights camping 2015, 45 in 2016, 42 in 2017
CNYCamper is offline   Reply With Quote
Old 03-01-2016, 02:03 PM   #10
TURBS's Avatar
Relieving the water pressure is the key!
Once relived
That filter housing will unscrew easily.
When reinstalling DO NOT tighten housing, just align the arrows and the tab.
If used correctly this housing and filter are great!
People that do not know how the system works tell you to just throw it away and buy something else.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
water, water filter
