Old 11-03-2014, 07:30 AM   #11
New to Forest River
Roving Ron's Avatar
Originally Posted by Lon View Post
I am a newby and was thinking the other day(I've gotten in trouble doing this in the past) about a way to reverse flush the back water tank. This is probably ludicrous but I'll ask any way. Would it be possible to do the following: 1. drain the black tank in the standard fashion
2. put the outside cap back on the common drain(that drains both the gray and back water tanks)
3. open the full gray water tank valve and let this high pressure
water run backwards through the connecting pipe, into the back water pipe and into the black water tank.
4. Then before the pressure equalizes in the two tanks quickly shut off the gray water drain valve so no black tank water gets into gray tank. 5. Then once again drain the black water tank in the standard fashion.
I can hear the old timers now. "what an idiot!" But none the less, is this doable? Thanks
What about the gallon or two of liquid between the black/grey valves and the cap to the sewer outlet. Could be a nasty surprise when you remove the cap to attach the drain hose.
Grey Nomads, Ron and Sue
Grey Nomads:l Ron & Sue
Roving Ron is offline   Reply With Quote
Old 11-03-2014, 07:53 AM   #12
Herk7769's Avatar
Watch all of this ...
Cool Flush Tool Comparison
HAM CALLSIGN - KC3FFW
Old 11-03-2014, 08:23 AM   #13
RV Hydro Flush 45 Degree - Valterra F02-4100 - Sewer Flushing - Camping World
I use one of these with a dedicated hose.
Silverado HD 2500 6.0 Crew Cab
2014 Roo 21ss
sdelam is offline   Reply With Quote
Old 11-03-2014, 08:36 AM   #14
Isn't one of reasons we have 2 separate tanks to minimize the chance of cross contamination?
hud
Hudlow is offline   Reply With Quote
Old 11-03-2014, 08:46 AM   #15
mTn_biKer65's Avatar
I'm not a fan of the idea because you'd be introducing black water into the grey water tank. But that said to get it to work you'd need to add a second gate valve to keep the mixed dirty water away from the cap or you'll get a nice shower when you remove the cap to reconnect the sewer hose.
There was another thread here recently about taking the sewer hose once it's full and lifting it thus forcing a wave of dirty water back into the tank in an attempt to clean out a little more. If you have 3 hands you might be able to do some fancy gate action to get the grey into the black using this method. Wear & tear on the sewer hose and increased potential for a disgusting catastrophe are the obvious deterrents.
Nights camped
2007 Shamrock F19 hybrid - 2010 (22 nights), 2011 (24 nights), 2012 (11 nights)
2013 Surveyor Select 235RKS -
2012 (6 nights), 2013 (32 nights), 2014 (26 nights), 2015 (37 nights), 2016 (14 nights)
mTn_biKer65 is offline   Reply With Quote
Old 11-03-2014, 09:34 AM   #16
mark0224's Avatar
First as others have mentioned you would be wearing it when you took the cap off, second this wouldn't stir things up enough to do much good. I don't think those back wash pieces you put on and connect the hose to work enough. I like the wand, with the flexible hose, that goes in through the toilet. Just wish you could see to control the end so you get everything. Use it a couple of times a season so you don't get any build up. If they made the tanks so there were no corners at the discharge end would help.
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 11-03-2014, 09:37 AM   #17
in order to avoid any cross contamination and the possibility of a grey or black water bath, i would use this
Amazon.com: Valterra F02-4350 Reverse RV Flush Valve: Automotive
I used it last week to flush my black tanks b4 I put it away for the winter.
2015 Ram 2500 4x4 6.4l with 2015 Sandpiper 25RLS
Wife, myself and 2 furry kids
Mountndream is offline   Reply With Quote
Old 11-03-2014, 10:30 AM   #18
Herk7769's Avatar
I threw away ALL my "hose/clear plastic" type flushers and installed a turboflush in my gray tank as well as the OEM one in the black tank after watching that video.
Those "back flush" types are a waste of money IMO. I also have an end cap shutoff valve but only use it to prevent "wet shoes" in case a valve sticks open.
black, black water, tank, water, water tank
