Old 11-01-2014, 09:26 PM   #1
Lon
Lon's Avatar
Reverse flush the black water tank?
I am a newby and was thinking the other day(I've gotten in trouble doing this in the past) about a way to reverse flush the back water tank. This is probably ludicrous but I'll ask any way. Would it be possible to do the following: 1. drain the black tank in the standard fashion
2. put the outside cap back on the common drain(that drains both the gray and back water tanks)
3. open the full gray water tank valve and let this high pressure
water run backwards through the connecting pipe, into the back water pipe and into the black water tank.
4. Then before the pressure equalizes in the two tanks quickly shut off the gray water drain valve so no black tank water gets into gray tank. 5. Then once again drain the black water tank in the standard fashion.
I can hear the old timers now. "what an idiot!" But none the less, is this doable? Thanks
Lon is offline   Reply With Quote
Old 11-01-2014, 09:34 PM   #2
Sure,let us know how it turns out! Just use whats left of the Gray for final rinse! Youroo!!
Old 11-01-2014, 09:35 PM   #3
Indymule's Avatar
I agree, stop thinking! I have the same problem, I'm an idea man.
It would back flow into black tank until the pressure equilized but WHY would you want to do that?
It would not effectively clean your black tank, potential put black tank materials into grey tank and you would loose having the soapy gray tank water to help flush out slinky.
There are much better ways to clean the blank tank
Jay & Maria - Camp Dog Joplin
2018 Cedar Creek Champagne 38EL
Fulltimers since May 2018!
2017 Ford F350 Crewcab Dually Diesel
Officially homeless and loving it.
Ham Callsign K9NDY
Indymule is offline   Reply With Quote
Old 11-01-2014, 09:43 PM   #4
Hey Indymule, are you going to (The Big Show) Westminster? Youroo!!
Old 11-01-2014, 09:53 PM   #5
Indymule's Avatar
QUICK HIJACK
No after Amana, I can't lower myself to do Westminster
NOW BACK TO YOUR REGULARLY SCHEDULED THREAD
Ham Callsign K9NDY
Old 11-01-2014, 09:59 PM   #6
Indymule's Avatar
Oh and by the way Lon,
There would still be gray/black water in the pipe (not a lot but enough) when you removed the cap again, thereby giving you another shower.
Just a thought!
Ham Callsign K9NDY
Old 11-03-2014, 12:15 AM   #7
Lon
Lon's Avatar
Thanks. What stimulated these erroneous thoughts was the realization that when its time to shut down and get back on the road my gray tank is full and the black tank is only a quarter full. So I mused there ought to be a way to get that perfectly good soapy water from the gray tank into the black tank for a good purge. It could be pumped over with a backflow preventer. Forrest River could offer this as a thousand dollar option and I won't charge them a thing. :-)
Old 11-03-2014, 05:50 AM   #8
Witch Doctor's Avatar
I don't know if you could have enough pressure to do what you want. Your discharge lines go's down on both so you would have to go up hill while still holding the black in the tank which is above the outlet. Wouldn't it be easier to just dump your gray in a bucket and dump it in the toilet?
Coachmen M/H
Concord
2018 / 300 DSC
Old 11-03-2014, 07:33 AM   #9
First things first, you need a valve on the outlet, not a cap. Twist-on Valve - Valterra T58 - Sewer Fittings & Adapters - Camping World Unless you want to be like Robin Williams in the movie RV!
Water will run up hill because water seeks its own level. If the water level in the grey tank is higher than the water level in the black tank (and it would be if the black was empty and the grey was full), the water from the grey tank will enter the black tank until the levels are equal. You would then want to close the grey valve and open the twist on valve to empty the black tank again. Finally, finish up by closing the black valve and opening the grey valve. I've done this when I couldn't use my tank flusher, but it surely does not work as well as the flusher.
2012 CC 36CKTS Touring Edition
2015 Ford F-350 CC DRW Lariat
Joe_GA is offline   Reply With Quote
Old 11-03-2014, 08:00 AM   #10
Mddle of the Rd Extremist
MeepMeep's Avatar
Why not keep it simple (and prevent the "Robin Williams moment") by draining your black tank and then refilling it with fresh water via the commode and dumping it again?
Dan, Carolyn & The Bandit (1999-2015 RIP...)
MCPO (Retired)
United States Navy ('65 - '87)
2014 Cedar Creek 38FL
2013 RAM 3500 6.7L diesel DRW Crew Cab
"When you get to the fork in the road, take it....."
MeepMeep is offline   Reply With Quote
black, black water, tank, water, water tank
