Old 06-12-2011, 10:06 PM   #1
Rockwood 2304 water heater popped!
We were trying to light the water heater, it clicked a few times and then popped real loud. It literally got so hot it melted the caulking around the water heater! Now the gas water heater does not work, but the electric does. My question is the electric water heater part of the thing ok to use all of the time. The camper is still in warranty, and I will get the heater fixed, but the electric works better in my opinion.
rthrbcampn is offline   Reply With Quote
Old 06-12-2011, 10:12 PM   #2
sherdep's Avatar
I use my electric portion of the water heater - have only tried the propane side to make sure it worked.
Just one thing though is make sure you turn the switch off on the water heater before disconnecting the water.
sounds like a mud dobber or something got into the water heater (gas side)
I put a screen on mine as soon as I brought the camper home so I ouldnt give mud dobbers a home
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 06-13-2011, 09:35 AM   #3
As long as you plan on only camping at electric sites, that plan will be fine. We figure if you're paying for an electric site, use electric on the fridge and Water heater. Why burn up your propane unnecessarily??? I would definitely get it repaired, while it is still in warranty, though. If it IS mud daubers or some other creature that stopped up the vent flue, they probably won't cover that on warranty, however. Good luck, Randy
