Old 03-26-2014, 03:24 PM   #1
Rockwood 8280ws shower leak
Hi all getting a few drops in the compartment under the shower after every shower. Have tried calk but no luck maybe from the faucets ? any one have this problem. still under warranty but not close to the dealer..
hdreby is offline   Reply With Quote
Old 03-26-2014, 05:14 PM   #2
Senior Moment
rockport's Avatar
Not sure if this will help at all, since I have the 8289ws model. My drain pipe is exposed under shower in the storage compartment and I noticed it was getting wet, I must have hit the plastic pipe loading things in. Anyways ended up replacing the drain for about $5.00 part at home depot. They are the ones sold for Mobil homes. Now I'm more careful when loading things in there.
Sent from my HTC One using Forest River Forums mobile app
rockport is offline   Reply With Quote
Old 03-26-2014, 06:57 PM   #3
I had the same issue. Mine was a loose union in storage compartment. Must have hit it a few times loading and unloading.
Mike Tav is offline   Reply With Quote
Old 03-26-2014, 07:07 PM   #4
Thanks all my drains are exposed and dry
Old 03-26-2014, 08:16 PM   #5
VinceU's Avatar
Try the screwed faucet fitings behind the shower wall. Remove faucet and check the hot and cold connections. Also change the sealant when you install the faucet base to wall. I've found both types off leaks in two seperate RV's
Old 03-27-2014, 07:53 AM   #6
thanks I will give it a try
280, 8280ws, leak, rockwood, show, shower
