Old 07-22-2015, 05:53 PM   #1
Rockwood Premier 2516 Bad Tasting City Water
Hey everyone,
Fairly new to the forums and I have owned my 2012 Rockwood Premier 2516G popup for about 3 months. We've taken it out on a few trips already and have literally no problems but one. Everytime we run the sink on city water it has a bad smell and taste to it. This last trip, over a 3 day, I had ran the sink on city water for about 2 hours and it seemed to be getting better. But later that same day, the bad taste/smell came back. It vaguely smelled like fruit loops the cereal. Not sure what's going on either. I haven't checked the water filter yet and to my knowledge the city water doesn't get anti-freeze put into the system during the winter. The problem happens when the water heater is on and off so I don't think that that's the problem. If you need anymore info ie, part numbers/pictures, let me know and I'll get them up. We're going again this weekend and I'd like to get some ideas of how to fix it before we leave so I can troubleshoot. Thanks!
Tony
kausticklown is offline   Reply With Quote
Old 07-22-2015, 05:58 PM   #2
BendOrLarry's Avatar
Originally Posted by kausticklown View Post
Hey everyone,
Tony
You should be okay at least it doesn't smell like Captain Crunch! sorry couldn't let that one get by me. It's possible you are smelling what's left of winterizing anti freeze. Some brands smell different from others. I would just keep running good fresh through the system, it should get better soon.
2009 Sunseeker 2860DS
Bulldog keyless entry
Firestone airbags
Airlift remote compressor system
Ultragauge EM Plus OBDII monitor
BendOrLarry is offline   Reply With Quote
Old 07-22-2015, 05:59 PM   #3
Georgia Rally Coordinator
aceinspp's Avatar
First thing to do now is drain the hot water system. Then fill your FWT and add about a cup of bleach. turn on the pump to fill hot water tank and water running through all tap. Then let sit for a day then drain the whole system again and then flush with fresh water. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10 gear
Days camped 2017 62
Days camped 2018 67
Days camped 2019 30
Old 07-24-2015, 03:10 PM   #4
MacDR's Avatar
I learned a quick trick this weekend, since we don't drink the water from the tap and only use it for washing dishes and showers.. It was suggested just filling the water filter canister with bleach and then run water from the city water connection through the hot and cold water .. Got rid of the funky smell in 5 minutes.. Quick and painless..
2013 Ram 2500 "Cummins"
2014 Columbus 340RK
28 Days camping 2015
2014 Columbus 340RK
Day's Camped 2018 "32"
You can find us: CrockeryCreek RV Park, MI 9/29 - 10/1
MacDR is offline   Reply With Quote
Old 07-24-2015, 03:46 PM   #5
brookstone345sa's Avatar
If trailer sits for awhile, it's always good idea to drain hot water heater.
brookstone345sa is offline   Reply With Quote
Old 07-24-2015, 08:53 PM   #6
Smile
Verify that your drinking water hose is manufactured/rated for "drinking water." Generally, that is always a white colored hose. Wal-Mart or any RV store sells the hose. IF you used a non-drinking water hose, i.e. a garden hose, etc. you have contaminated your water system with a chemical taste. Tastes horrible but will not harm you. If the latter hose was used, the best suggestion I have is decontaminate the taste with a heavy dose of bleach water. This may be required two-three times or more. In my "infancy years" of RV ownership, I used a gas station hose for convenience. Took about a year to neutralize the chemical taste! Good luck!
l001952119 is offline   Reply With Quote
rockwood, water
