Old 11-08-2010, 10:19 AM   #1
Rookie plumbing question
Water in my fresh water tanks is plumbed to go where???(sinks??)
water that I hook up at the CG in plumbed to go where???Showers??
and also, when I dump the black and grey tanks it doesnt seem to drain completelty, any tricks or suggestions???????????
TT-2014 Coachmen 320bhds Freedom Express-50 Yr Anniversary edition
TV-2016 Dodge Ram 2500 Cummins Diesel 4x4
2010 Road Glide Harley Davidson FLTRX
boudie is offline   Reply With Quote
Old 11-08-2010, 10:46 AM   #2
MtnGuy's Avatar
Both the city water and fresh water tank are plumbed to go the same place.....all of your faucets.
Check to see exactly where the drains come out of your tanks. I need to be tongue high, level side to side to completely empty my black tank, and tongue low, street high to completely empty my gray tank.
Old 11-08-2010, 11:26 AM   #3
Water is plumbed to kitchen faucet, bath faucet, inside shower, outside shower (if equipped), water heater, and toilet flush valve. Fresh water tank (exterior fill cap) uses a one way check valve when switching from city water- same plumbing outlets. Randy
Old 11-08-2010, 11:34 AM   #4
So I dont need to fill that tank for my trips if we have water hook ups.
correct???????????
Old 11-08-2010, 11:52 AM   #5
MtnGuy's Avatar
correct???????????
Correct.
I travel with a couple of gallons of water to flush the toilet and wash my hands.......I would rather use my own toilet instead of those at rest stops.
Old 11-08-2010, 04:41 PM   #6
If you do fill your fresh tank, be sure to keep it "fresh", by draining it upon returning home. You don't want the water to get stagnant. As I mentioned above, there is a check valve that is designed to prevent water from entering your fresh tank, when hooked up to city water. You must fill the fresh tank manually, at the separate fill cap. Randy
Old 11-08-2010, 05:01 PM   #7
Herk7769's Avatar
Just one water system
It looks like this:
HAM CALLSIGN - KC3FFW
Old 11-08-2010, 05:04 PM   #8
Originally Posted by herk7769 View Post
It looks like this:
Lou,
You always have the best diagrams!!!!!
Kirk, KN1B
2013 Cardinal 3800FL
2009 GMC 3500HD CC LB SRW
kbrown1075 is offline   Reply With Quote
Old 11-08-2010, 05:13 PM   #9
Herk7769's Avatar
I will share a secret, so DON'T tell anyone!
I open another window in my browser and do a quick Google search and bam! Someone already drew what I want! Then I upload it to Webshots and drop it into my post!
If you type fast enough, folks think you are brilliant!
So lets keep this between us.
Old 11-08-2010, 05:15 PM   #10
Deal! My lips are sealed!
Kirk, KN1B
