Old 09-10-2016, 04:05 PM   #11
Cyber Phrenologist
Radio's Avatar
I have noticed the anode rod fitting (or maybe the "bung hole"?) on my water heater has always been really rusty, since day one (8 years) but the tank itself has always been fine. Perhaps that's where your rust is coming from? When I clean/check my anode rod I scrub the fitting with a wire brush.
And to much Teflon tape may be an issue. Just enough so it doesn't leak and I usually leave the first few threads uncovered for a good "ground"
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
Old 09-10-2016, 09:49 PM   #12
DodgeNerd85's Avatar
Well i got a suburban brand anode rod, so well see if that helps, cause i did notice rust on the camco threads,
But does anyone know why there is this red crap in the hoses?
2015 Stealth 2812G
2012 3500 Mega Cab DRW
ISR Series SuperGlide 16K
GO NAVY
DodgeNerd85 is offline   Reply With Quote
Old 09-11-2016, 07:57 PM   #13
Cyber Phrenologist
Radio's Avatar
My best guess is left over antifreeze. Just about all the plumbing in an RV is plastic. The water heater tank is either aluminum or stainless steel. I can't think of any source of rust/corrosion that would leave a red stain inside the RV.
Aluminum will corrode/oxidize but that makes a grey color, not red.
KU4OJ
Old 09-13-2016, 07:30 AM   #14
DAISY BOYKIN's Avatar
Rust in lines
In manufacturing the tank, maybe the glass lining did not coat the entire
inside of the tank. This could cause the tank to show rust from the uncoated surface.
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
BOLIY PRO 3600SI GEN
DAYS CAMPED 2016 74 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 09-13-2016, 07:56 AM   #15
Would forest river use anti freeze from warehouse ? Ive never used it
2015 Stealth 2812G
GO NAVY
Old 09-13-2016, 08:03 AM   #16
Flybob's Avatar
It is possible that the campground water had a very high content of dissolved iron and when heated, it will precipitate out and cause the rust coloring you are seeing.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 09-13-2016, 08:04 AM   #17
Its really weird, from the fresh tank to the pump there is this deep red crud, it looks like a raspberry got into the tank, the stuff dries like a deep blood color...
I was able to get a scope maybe half way up the hose (from tank to pump) and its half way coated, there was a slight kink in the hose and i couldnt get the scope past it, but the hose looked clear at that point.
Again, im not sure that red crap got passed the pump because the sediment trap is clean on the pump itself...
As for the water heater itself, Im going to check it and the suburban anode rod later today to see if it helped with the rust. We used the trailer this weekend, so its only been sitting since sunday night. During the weekend, cold and hot water came clear from sinks and showers
2015 Stealth 2812G
GO NAVY
Old 09-13-2016, 08:10 AM   #18
I have no idea, but we would figure it would be happening to more people than me, usually the places i go too get super busy too.
2015 Stealth 2812G
GO NAVY
Old 09-13-2016, 08:12 AM   #19
My tank is aluminum, yours could be too. My guess is the water supply has a high iron content. Are you using a good filter in your water line before it goes to the water heater? Anode rods are pretty much the same. Your old one was working fine from the way it looked.
2015 Chev Silverado 3500 dually D/A
2016 Cedar Creek 36CK
B&W Patriot 18K, Trail-Aire pinbox,
Level up, dual panes & all that stuff...
GOTTOYS is offline   Reply With Quote
Old 09-13-2016, 08:14 AM   #20
Bingo!
Very common problem here in Western PA.
Iron filters are a must on most well supply systems.
Turns EVERYTHING red without.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
Ford F-Series SCREW 4x4
TST Tire Monitor - Sinemate 3500w Gen.
2016 Nights Camped = 46
heater, water, water heater
