Old 09-09-2016, 02:53 PM   #1
DodgeNerd85's Avatar
Rust in water heater?!?!?!
So i did my quarterly water heater check, rustly/brown came out of the relief valve! I drained the water heater and a little more rusty water came out. My anode rod looks brand new still (replaced earlier this year). I looked at the clear lines i installed at the tank and there is this red/blood like color coating the inside line, help! I cleaned i of the clear short hose, but its all the way up white oem hose going to the pump.
About to do the usual vinegar/water boil, but i feel there may be rust at the bottom of the water heater tank, should i boil some bleach in the heater?
I use city water, and always have the cheapy camco inline filter.
ID:	119805   Click image for larger version
2015 Stealth 2812G
2012 3500 Mega Cab DRW
ISR Series SuperGlide 16K
GO NAVY
DodgeNerd85 is offline   Reply With Quote
Old 09-09-2016, 03:01 PM   #2
wmtire's Avatar
Any chance you used RV anti freeze in the system over the winter?
2011 Flagstaff 831 RLBSS
Wanna know how I plan on cutting carbs next year?
With a pizza slicer.
Old 09-09-2016, 03:04 PM   #3
DAISY BOYKIN's Avatar
Rust in tank
I'm not sure if the small water tanks have a glass lining or not. I know the large home tanks do. It appears your zinc rod is not doing the job. I would replace the rod with a new one. There should not be that much rust in the tank to discolor the water lines. Is it still under warranty? some have a two
year warranty. I would contact the MFG of the water heater to inquire about the rust.
I have a tank that is 5 years old and no rust!
My two cents.
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
BOLIY PRO 3600SI GEN
DAYS CAMPED 2016 74 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 09-09-2016, 03:11 PM   #4
I did not, i live in san diego, figured i didnt need it. It hasnt been sitting long (a month), and when we used the trailer we didnt see any discolor from the sink or shower
2015 Stealth 2812G
GO NAVY
Old 09-09-2016, 03:17 PM   #5
My two cents.
From what i can see inside the little drain whole, it does look like there is some kind of coating. The zinc rod is a camping world brand i think
2015 Stealth 2812G
GO NAVY
Old 09-09-2016, 03:28 PM   #6
I just checked the sediment trap on the water pump, its clear, no red or rust, did find some plastic pieces and a dead bug, gross
2015 Stealth 2812G
GO NAVY
Old 09-10-2016, 01:47 PM   #7
Before any period of inactivity/storage I always flush the hot water heater thouroughly and after all the rust is gone it's good for the trip!
greymedic is offline   Reply With Quote
Old 09-10-2016, 04:17 PM   #8
DouglasReid's Avatar
Just a small pet peeve, it is a "Water Heater", not a "Hot Water Heater". If the water were already hot there would be no need to heat it, would there?
Maurice, LA
2012 Wildcat Sterling 32RL
2008 Chevy Silverado 2500HD LT Diesel
TST TPMS system w/ Flow-thru sensors
2001 Cougar 281 EFS (sold)
DouglasReid is offline   Reply With Quote
Old 09-10-2016, 04:44 PM   #9
if the rod looks new the problem might be too much telfon tape. Our tank has a blue lining.
chevman
labarn is offline   Reply With Quote
Old 09-10-2016, 04:47 PM   #10
Mr. Dan's Avatar
If the water coming OUT of the heater is hot, could we call it a "Hot Water Maker"?
SEARCH is your friend!
Nights Camped: 2013 = 49 / 2014 = 74 / 2015 = 74 / 2016 = 85
heater, water, water heater
