Old 09-16-2014, 09:27 AM   #11
Bilcin's Avatar
I replaced the annode rod in May after 3 years, it still had half of the material on it but replaced anyway. I will look at the camp ground and it does have well water. On my Suburban water heater, how do you guys get all the water out? I would have to put my trailer on it's side to get all the water out, the plug/ anno rod is not at the very bottom of the tank.
Bill & Cindy McKenna
Philadelphia PA
2015 Palomino Puma 32DBKS
2005 Ford Excursion 6 liter Turbo Diesel
Bilcin is offline   Reply With Quote
Old 09-16-2014, 09:49 AM   #12
VinceU's Avatar
Atwood=Alum. Can pit and corrode if not maintained.
Suburban=Steel will corrode and waste out if not maintained.
Maintained means follow mfg instructions.
Old 09-16-2014, 10:12 AM   #13
bend302's Avatar
Suburban describes its' tank as porcelain coated steel. That's pretty much like your glass lined home unit.
You could have some of that porcelain cracked off allowing the steel to rust but my money is on bad looking water. Flush everything out including removing the filter and flushing the tank by forcing water in the anode rod hole until it is all clear. Then see what next summer brings.
Yes, it's hard to get the water out of the tank. I park my coach on a sloped area by my storage unit, let gravity drain as much as I can and then a bunch of twisted paper towels to get out most of the residue. A small layer of water in the bottom of the tank won't expand enough to do harm. Also, leave the anode out over the winter.
Bill
Life is a journey, not a destination.
2005 Georgetown 359ts
Bill & Virginia, Kentucky
Nights camped in 2011...78 , 2012...73,
Nights camped in 2013...123, 2014 ...101
bend302 is offline   Reply With Quote
Old 09-16-2014, 10:18 AM   #14
MtnGuy's Avatar
I do about the same thing with paper towels, but let them hang down the side of the trailer so the water is wicked out of the water heater.
Leaving the anode rod out over the winter is an invitation for critters to check out the tank.
Old 09-16-2014, 10:33 AM   #15
wmtire's Avatar
Cool idea on the paper towels, Chap.....and X2 on not leaving the anode rod hole open, as it's an invite for things to fly/crawl/walk/slither into it.
2011 Flagstaff 831 RLBSS
Never Apologize! Never Explain!
Sorry, thatís my motto.
Old 09-16-2014, 02:05 PM   #16
Herk7769's Avatar
This is also my technique to get the last of the water out after flushing with a wand.
Name:	Hot Water Tank Clean out Wand.jpg
ID:	62909   Click image for larger version
HAM CALLSIGN - KC3FFW
heater, water, water heater
