Old 09-15-2014, 09:16 PM   #1
Bilcin's Avatar
Rust in water heater?
I have just winterized my 2011 Forrest River 26TBSS. While blowing out the water lines, every faucet that I drained the hot water side from had rust colored water coming out of the faucet. I keep the water in the hot water heater all season, is that a mistake. Am I supposed to empty the water tank after every trip? How do I get rid of the rust colored water? Flush the hot water heater by running water through it??
Bill & Cindy McKenna
Philadelphia PA
2015 Palomino Puma 32DBKS
2005 Ford Excursion 6 liter Turbo Diesel
Bilcin is offline   Reply With Quote
Old 09-15-2014, 09:25 PM   #2
The tank should be aluminum, sometimes when I remove the anode rod there is sometimes a scaly mineral gunk on it but I have never had rusty colored water come out of any of my faucets. I would remove the rod and check it, the only thing that I can think of is maybe the nut on the anode rod is rusting and making the water rusty colored I would flush out the whole system especially if you are going to let it sit all winter and use some rv antifreeze once done.
Mike, Lisa and Jake
2002 Ford F250 CC 7.3
2013 Wildcat Sterling 32RL
MMattox is offline   Reply With Quote
Old 09-15-2014, 09:42 PM   #3
Bilcin's Avatar
Thanks, however, I thought the hot water tanks were metal, which is why we need an annode rod to rust instead of the tank, I thought aluminum didn't rust.
Philadelphia PA
Old 09-15-2014, 09:55 PM   #4
Windywest's Avatar
The anode rod doesn't rust, it's for mineral deposits
Cheers from Alberta Canada
2011 Flagstaff 8526RLWS 5th Wheel
2011 Ford F250 4X4 Crewcab Superduty 6.7L Diesel
B&W 3300 Hitch for Ford 5th Wheel Prep package
Windywest is offline   Reply With Quote
Old 09-15-2014, 10:01 PM   #5
BooBoo23's Avatar
The anode rod is sacrificial and it does not rust it erodes through electrolysis to protect the tank from rust and corrosion. If you have never drained the hot water tank when you winterized you are lucky that it didn't freeze and split. Sounds like you may have a Suburban water heater. I'm going to guess you have never replaced the anode rod. If not you are overdue. If there is rust in the tank about the only thing you can do is put a filter on the hot water after the tank for the time being. You may be looking at a new water heater down the road. Remove the anode rod to drain the tank and lift the relief valve to drain it faster. Also, be sure to put RV anti-freeze in the traps of the sinks and tub/shower to keep any remaining water in them from freezing and splitting them. Since you are blowing out the lines there is no need to use the bypass system. And, it would be a good idea to drain your water heater tank as well as the fresh water tank if the trailer will not going to be used for several weeks to keep any growths out. So, if you don't drain the hot water tank the trailer is not winterized.
2014 Palomino Puma 25RS
2011 F-150 Super Crew XLT
Days camped in 2014 - 23 Camped 2015-47
Camped 2016-71, 2017-33, 2018-29 booked
BooBoo23 is offline   Reply With Quote
Old 09-16-2014, 06:07 AM   #6
Bilcin's Avatar
I always drained the water heater at the end of the season, and replaced the annorod in May. I had no problems, including Labor day when the hot water was clear. I only noticed the orange tinted water coming out ot the hot water side when I winterized my trailer on Sunday. Did not think rust would set in so fast???? For the last 3 years I was lucky with my traps, fogot all about them until I opened up the trailer for Memorial Day, bathroom sink trap leaked, so I already did the antifreeze in all the traps. Thanks for your advice.
Philadelphia PA
Old 09-16-2014, 06:30 AM   #7
Rust can come from a repair in your system if a (Steel/castiron) fitting was used! Also if you? (Dry shot) your Suburban W/H on (Gas) it can cause the (Coating) inside the Tank to crack and start to (Rust) also! Youroo!!
Old 09-16-2014, 06:36 AM   #8
Herk7769's Avatar
Where did you camp? Is it possible all your water is "rusty"?
If the well that the campground used was low, you may have gotten fine silt (reddish) in your water supply. Your filter (if you have one) may be in "bypass" due to it being clogged.
HAM CALLSIGN - KC3FFW
Old 09-16-2014, 06:47 AM   #9
Good point Herk,we overnighted in PA along Route#6,Mom & Pop CG. Their Water was (Blood Red) we didn't take on or use any of it (Water),the (Restrooms/Showers) were the same way! Youroo!!
Old 09-16-2014, 06:55 AM   #10
Herk7769's Avatar
The anode could have been replaced "too late" and there may have been considerable rust already there and the new anode is knocking it off the tank fittings not covered in porcelain.
The only other option was a badly installed new anode ("Non-Teflon" Pipe Dope instead of the Teflon type or tape). If the anode is not making a good bond with the tank threads, it may not be working at all.
ID:	62886   Click image for larger version
heater, water, water heater
