Old 02-08-2016, 08:32 PM   #11
TURBS's Avatar
Rv antifreeze freezing
Originally Posted by Major View Post
Generally RV Antifreeze is good to about -20 to -50 at full strength depending on the brand, but the more water that is mixed with it the higher the freeze temperature will be.
If you poured it in full strength and did not add any water you should be fine (it must have been REALLY, REALLY cold to start to freeze).
I live in North Carolina so I don't have to worry about really cold temps for extended periods (teens usually for a few days is about as bad as it gets) so I don't use RV antifreeze at all anymore. For me it is too much hassle.
For years I have only used an air compressor to purge the system after opening the low point drains and emptying and bypassing the hot water tank and have not had any issues.
If you purged the fresh water tank with the water pump after draining the tank completely, for me here that would be fine because any water left in the tank or line would have plenty of expansion space after freezing and would not hurt anything.
Respectfully this is very bad advice you never want to add water to Rv antifreeze, it is NOT like automotive antifreeze!
From camco
• Protects to -50F (-46C) • Safe • Odorless • Tasteless • No mixing required • Non-Toxic • Propylene Glycol base • Safe for fresh water systems • High grade antifreeze for complete freeze protection requirements • All ingredients are listed in the U.S. Federal Register (GRAS)
The only time you ever add water to Rv antifreeze is if its concentrate, and I've never seen anyone have Rv antifreeze concentrate.
I guess I may have miss understood what you were saying.
I'm not sure why anyone would want to add water which is why I questioned your post.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
Old 02-08-2016, 08:44 PM   #12
MNtraveler's Avatar
It's frozen in the toilet up here, but I'm not sticking my finger in to see if it's a slushy! Like others said, it will freeze but won't expand and crack your lines and fixtures.
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
Old 02-08-2016, 09:00 PM   #13
Rv antifreeze will definitely freeze (depending on temperature). but being non toxic and all that other jazz, its got just enough antifreeze to keep it from expanding enough to burst pipes/fittings, it will just turn into a slush unless temperatures are well below its rated limit. the expansion rate of frozen RV antifreeze is much lower than that of plain water
Most RV antifreezes are ethanol(alcohol) based, making them non-toxic, but they still freeze to some extent and turn into a slush. If you by some chance used glycol based rv antifreeze (its not very popular, especially for domestic sale), if its frozen, its either a bad concentration or a bad batch.
Lets assume you used the standard and readily available ethanol/alcohol based antifreeze. If you allowed the water lines to purge generously with the antifreeze you will be more than fine down to whatever its rated temperature is. It will still freeze to a slushy consistency, but no harm done
'14 XLR 395AMP
'16 Ram 3500 DRW, 6.7 cummins w/aisin trans and 4.10 gears
ykdave is offline   Reply With Quote
Old 02-09-2016, 06:23 PM   #14
Major's Avatar
From camco
2015 Columbus 320RS
2008 2500HD Duramax
TURBS,
Read my post again. I did not and would not suggest adding water to antifreeze I wouldn't do that to someone.
I was asking/questioning IF water HAD been added. Not trying to be picky... just setting the record straight
Doug and Becky Ridgeway
2014 Blue Ridge 3600RS
2014 Ford F-350 CC 4X4 DRW 6.7 PSD
Troy, NC
Major is offline   Reply With Quote
Old 02-09-2016, 06:30 PM   #15
AquaMan's Avatar
TURBS,
I understood what you were saying, but had to read it a couple times. I think he read it as I first did and misunderstood what you were saying.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 02-09-2016, 07:51 PM   #16
TURBS's Avatar
Which I commented about in at the end of my quote
2015 Columbus 320RS
2008 2500HD Duramax
antifreeze
