Old 03-09-2016, 04:59 PM   #1
garmford's Avatar
RV plumbing pipes
Does the black pvc waste pipes under the sinks of my camper interchange with the white pvc that we use in our houses?
My "pop a vents" under my sinks went bad and I am finding that they are a pain to find and rather expensive to replace(considering what and how their made). I'm looking to redo the plumbing under the sink so I can replace it with a better vent that I can buy from a home improvement store.
Or does anybody have a good website where I could buy new ones for a relatively good price?
Thanks a million!!
Matt
2012 F350 DRW 6.7 PSD
Blue Ridge 3710 BH
garmford is offline   Reply With Quote
Old 03-09-2016, 05:05 PM   #2
fonzie's Avatar
is this what you are talking about "air admittance valve"?
Search Results for¬*air admittance valve¬*at The Home Depot
Fonzie
Old 03-09-2016, 05:19 PM   #3
garmford's Avatar
That's what I'm talking about. The camper has a fixed 1 1/2" female and the admittance valve is 1 1/2" male. The ones I've seen at Home Depot say they are 1 1/2" but they are female if I remember correctly. I've checked menards too. That's why I had the thought of changing the plumbing to accept the valves that I can readily buy from Home Depot.
That leads me back to my original question, does the white pvc work with the black pvc?
Blue Ridge 3710 BH
Old 03-09-2016, 06:06 PM   #4
Left Coast
Using the correct glue...
Old 03-09-2016, 06:14 PM   #5
fonzie's Avatar
x2
http://www.oatey.com/products/plasti...n-green-cement
Fonzie
Old 03-09-2016, 06:21 PM   #6
nomad297's Avatar
There is no correct glue. The black pipe is ABS and the white pipe is PVC. There is no glue made to join the two together. The joining of the two must be mechanical -- threaded, rubber, etc., but no glue. I know this because I am a plumber and have been for over three decades. You can take my answer to the bank.
Bruce
Old 03-09-2016, 06:23 PM   #7
fonzie's Avatar
Some of the RV air admittance valve are screwed in......
Shop Keeney Mfg. Co. 1-1/2-in Plastic Mechanical Plumbing Air Admittance Vent at Lowes.com
Fonzie
Old 03-09-2016, 06:25 PM   #8
nomad297's Avatar
If you want to join a 1-1/2" female ABS fitting to a 1-1/2" PVC female fitting, put a short 1-1/2" galvanized nipple between the two.
Bruce
Old 03-09-2016, 06:27 PM   #9
nomad297's Avatar
Originally Posted by fonzie View Post
The Keeney valves are junk -- that's why they're in our RVs. Buy one made by Studor or Oatey.
Bruce
Old 03-09-2016, 06:27 PM   #10
caper's Avatar
All plumbing used in a RV is the same as you would use in your home. You can change the plumbing as needed.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
plumbing
