Old 12-28-2014, 07:45 PM   #21
Thurman's Avatar
I understand that all those macerator pumps, flo-jet thingy's will help empty the tanks although I am wondering if they will pump efficiently for that ninety-two (92') run that I will have. Now--read post #5 where I stated that I will also be tying in a sink that is currently in my shop to this lift station. When I built my shop back in 1996 I put in twenty-foot (20') of drain tile set in three foot wide by three foot deep trench lined with a "root barrier" then #52 gravel was put in, more root barrier across the top then fill dirt. This plan was given to me by the local county planning office and should have lasted longer than I would live. For some reason this drain is now somewhat, mostly, almost, stopped up. The lift station will be utilized for two purposes, the shop sink and the RV dump. As far as the cost-about $500 total including all PVC piping to the sewer line coming from the house. This is for a "Little Giant commercial" thirty-gallon in-ground fiberglass tank, a "sewerage" rated 220v pump which will handle 1/2" solids, a float switch, and a back-flow prevention valve. We had these where I used to be employed before retiring. We used this brand, and model, at various locations in the plant and they performed very well. My goal is to bring the unit home, wash the tanks out really well, place about five-gallons of water and a "green friendly" bactericide in them while they sit until the next trip. IF I had MY way--the unit would stay on the road, but the boss-lady has a job so we have to come home way too often.
Thurman is offline   Reply With Quote
Old 12-28-2014, 07:57 PM   #22
John McClain's Avatar
I might be faster to install a small septic tank a leach line next to your rv
F-250 . stealth 3210 solar pannels, fantastic fans. and life line batteries
John McClain is offline   Reply With Quote
Old 12-28-2014, 08:59 PM   #23
mattb's Avatar
I put a Saniflo system in the basement, ours allows for the toilet plus a sink and a shower. More models now than there were. Ours runs on 120v 15a cord, and pumps out through a 3/4" pvc line, which is tied to our main line. IIRC it has plenty of head and length ability. Check them out.
SFA product line for homeowners.
2008 Roo 21SS
2003 GMC 1500HD 4X4 6.0 3:73 Diablo tuner
mattb is offline   Reply With Quote
Old 12-29-2014, 11:54 AM   #24
Thurman's Avatar
@ John McClain: I did think about this plan. My county requires a minimum 1400 gallon septic tank and a whole bunch of leach field lines. Something near $6000 to do this just for the RV and shop sink. I think not. @ mattb: Thanks for that info. One odd thing is that I have been working with "Albany Winnelson" who is listed as a distributor for the SFA products but they have not mentioned this system, they highly recommended the Little Giant system. One thing I noticed is that the SFA system appears to be built to be installed inside a building, whereas the LG system is a ground burial system. I'll check further into the SFA system also.
