Old 10-18-2017, 06:31 PM   #1
Salem T27DBUD Septic Replacement Valve Help.
[ATTACH]Click image for larger version
Name:	black valve bristol.jpg
My apologies for grossness... Where can I find a replacement for black water valve? The plunger is either broken or stuck, just soon replace both grey and black.
Thank you!
Name:	black water valve.jpg
jpwhit1 is offline   Reply With Quote
Old 10-18-2017, 06:48 PM   #2
crunchman12001's Avatar
Google is your friend......
https://www.amazon.com/Lasalle-Brist...onda+Valve+Kit
2015 F-250 FX4
Old 10-18-2017, 07:16 PM   #3
I guess I was overthinking the part. I thought maybe it was the whole assembly.
Old 10-19-2017, 04:06 AM   #4
Just a gate valve.
2015 F-250 FX4
Old 10-19-2017, 12:30 PM   #5
Try something first ( I have done this) Get a mal zerk grease fitting. Drill a hole in the edge of the of the gate valve. Screw in the zerk (the threads will self tap the hole that you drilled). Pump some grease in the gate valve and that will be the end of all your valve problems. I just wish I could do this in my 5th wheel - all the gate valves are hidden and basically unavailable unless I peel off the bottom of the rig
Kayo
2014 Primetime Sanibel 3051 pulled by a 2013 Chevy Silverado 3500HP dually diesel. Full timers wince 2003 with DW of 53 year. NPS Park Ranger
kayo is offline   Reply With Quote
Old 10-20-2017, 12:01 PM   #6
RVdoctor
Gate valves should be considered a normal maintenance item and be changed periodically. When they become hard to operate just change them. Rubber parts do not respond well to grease over time. I would change them all at the same time since you have all the tools and mess anyway. They are cheap enough to purchase.
rvdoctor is offline   Reply With Quote
replacement, salem, valve
