Sandpiper 365RL fresh water tank drain
The fresh water tank drain in my 2012 Sandpiper 365RL appears to be the standard type with a fitting and cap at the end of the drain line. However, my filled tank is not draining. This RV is new to me and the previous owner reports the fresh water tank was never filled. Am I missing a drain valve somewhere? When I insert about 8-9" of hanger wire I hit hard plastic. Is the drain a straight line from the bottom of the tank, or does it have a 90 degree turn as it comes out the side? BTW, my 12V Sureflo pump is running when switched on put is no longer pumping although it did earlier this season and the tank is full. Overflow line is venting and draining normally. Just wondering if the two problems are related. Any help would be much appreciated. Thanks.
