Old 04-24-2016, 09:29 PM   #21
VinceU's Avatar
Originally Posted by vasnipe View Post
Yes, you can put the bleach solution in the water heater.
Just be sure to drain and flush the bleach water out, pull your anode rod, but open a water tap or lift the heater relief valve to release water pressure from the system first so you don't get soaked.
Chris in Virginia
Bacteria that cause "rotten egg smell" thrive in water heaters, hot or cold. If you are sanitizing anyway, good chance for some preventative treatment. Cut in the water heater.
Old 04-24-2016, 09:50 PM   #22
Herk7769's Avatar
While I isolate the water heater during winterization and the entire "de-winterization" process (to keep crap out of my pipes); I sanitize the system AFTER I fill the hot water tank.
That way the tank gets a good dose of chlorine.
If you decide to drain after sanitization, be sure to "re-isolate" the water heater so the crud in the bottom of the tank won't get into your pipes.
My technique is to just drain the fresh water tank (only) completely after sanitizing the system and then refill it with house chlorinated water. Then I just run the hot and cold water through the taps till the chlorine smell is gone.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
bypass
