Old 04-21-2016, 04:17 PM   #1
jheacox1's Avatar
Sanitize in bypass or not?
Looking for a little advice. Do you guys sanitize in the WH bypass position or open it up to also sanitize the WH tank?
2015 Rockwood Signature Ultra Lite 8281WS
2015 F250 Crew Cab
jheacox1 is offline   Reply With Quote
Old 04-21-2016, 04:26 PM   #2
fonzie's Avatar
I include the water heater...
Fonzie
Old 04-21-2016, 04:32 PM   #3
I sanitize the water heater too, fill it up first then top off the fresh tank again and sanitize the rest of it. When you drain and flush after a day or 2, drain the water heart then fill the system up with water again and flush out the lines. I also use one of the fresh water conditioning products, I like the non-bleach products, all the time to keep the system fresh through the season.
Steve
Golden CO
2016 Grey Wolf 26RR Limited
92 GMC K2500 454
2006 Honda Rubicon ATV
zuterbru is offline   Reply With Quote
Old 04-21-2016, 04:43 PM   #4
TURBS's Avatar
Sanitize while bypassed
2008 2500hd Duramax
2015 Columbus 320RS
2016 nights camped "0"
2015 nights camped "34"
Old 04-21-2016, 05:31 PM   #5
Pickin' & Campin'
X2
If you drained and cleaned the water heater during winterization it's ready to go.
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 04-21-2016, 05:43 PM   #6
TURBS's Avatar
X2
Agreed.
If sanitizing the wh you have to drain it again
Old 04-21-2016, 06:05 PM   #7
Who Dares, Wins
doc73's Avatar
I sanitize both...
Not trying to be a turd... But playing devils advocate... My tank was closed up all winter and so was my plumbing. using the "it was sealed and cleaned" argument would mean no need to do any sanitation unless you know something got in there.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is online now   Reply With Quote
Old 04-21-2016, 06:20 PM   #8
MtnGuy's Avatar
x2
Old 04-21-2016, 06:43 PM   #9
jheacox1's Avatar
Thanks everyone for your input. I rinsed the WH very well when/after winterizing....Accidentally ran some antifreeze into it like a doofus when I started winterizing. Totally forgot about the bypass valves on the first gallon and luckily had the rod out so I was promptly alerted as it poured onto the ground.
Maybe I should consider doing it with the bypass off after I flush the AF out. I'm going to use Springfresh to sanitize.
2015 F250 Crew Cab
Old 04-21-2016, 06:46 PM   #10
Dazed & Confused
M&K Hoffman's Avatar
2008 2500hd Duramax
2015 Columbus 320RS
Yep bypassed, dealt with the water heater last fall.
~Mike & Kim~
2014 Rockwood Windjammer 3008W Diamond Package
2012 Toyota Tundra Doublecab 5.7 4WD
M&K Hoffman is offline   Reply With Quote
bypass
