Old 03-24-2016, 12:06 AM   #21
MNtraveler's Avatar
By the way, the fresh water tank should have been emptied for winterization and should not have had antifreeze put into it. When it's empty, there's no reason to put antifreeze into it and doing that just adds to the difficulty of removing that taste. Next year you can avoid that.
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
Old 04-02-2016, 05:39 PM   #22
Too Tall's Avatar
Mixing chlorine and vinegar produces chlorine gas, not a good idea
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
Too Tall is offline   Reply With Quote
Old 04-02-2016, 08:02 PM   #23
c
By the time you have flushed the tanks a couple of times after sanitizing with ordinary household bleach, the concentration of chlorine is down pretty close to that of almost all municipal supplies in North America. Therefore it could only produce a very negligible amount of chlorine gas. So low in fact as to be virtually untraceable. If it were a problem you would never be able to use vinegar diluted with any municipal water supply anywhere. Granted, if you were to mix straight vinegar (full strength) with full strength household bleach you would see the reaction producing the chlorine gas. The method mentioned appeared a few years ago in an Oregon RV publication. The method has been used marine industry for some time when carrying out, what is know as, super-chlorination sanitizing of ships potable water holding tanks. I have not heard of any adverse reaction.
kcdelan is offline   Reply With Quote
