Old 03-13-2018, 08:46 AM   #1
Sanitizing question
When I sanitize my FW tank, do I keep the hot water heater on bypass or sanitize that too?
Kevin, Julie (DW), 5 kids
2017 Roo 233s towed with 2009 GMC Sierra 1500 Crew Cab
kevin79 is offline   Reply With Quote
Old 03-13-2018, 08:48 AM   #2
Many sanitize the water heater.
Through past discussions, I'd say about 75% do and the rest do not.
Days Camped: '16=46 '17=30 '18=51 '19=36
Old 03-13-2018, 08:58 AM   #3
SeaDog's Avatar
When I sanitize I do the hot water tank however I do not turn it on during this process
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
SeaDog is online now   Reply With Quote
Old 03-13-2018, 09:11 AM   #4
Either way your call But after your solution sits in the system for the recommended time turn off your Pump and City water,now open your H & C taps in the kitchen or bath,Now remove your Water Heater Drain Plug! This will allow Most of your Sanitizer and CRUD from your system to Exit out on the ground,Not Downstream in your water lines! Youroo!!
Old 03-13-2018, 10:10 AM   #5
WFD
I have mixed feelings about this one....last spring when sanitizing the water system, I opted to include the hot water tank in the process. I rinsed and rinsed and rinsed afterwards, but we had a bleachy hot water smell for quite some time afterwards before it finally disappeared. Made me think that I may just go back to bypassing it while sanitizing.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 03-13-2018, 10:13 AM   #6
marinerjoe's Avatar
Quick question - did you replace your in-line water filter? If not, that MIGHT have accounted for the lingering chlorine smell.
Joe
Current: 2018 Flagstaff MicroLite 21FBRS
Past: 2005 Flagstaff Classic 625D
TV: 2016 Ford F-150 3.5 EcoBoost
marinerjoe is offline   Reply With Quote
Old 03-13-2018, 10:19 AM   #7
WFD
I sure did....I pulled that inline filter right out of the system and bypassed it with my very first mod to the trailer. Thanks for that tip though, as that would certainly impact it and can be of benefit for others reading this.
