Old 07-11-2013, 03:05 PM   #11
TURBS's Avatar
Originally Posted by ptt87 View Post
Yes, the water heater is currently in bypass mode from being winterized.
I just ran the faucets a little longer and I still don't smell a strong odor. So I had my daughter come in with me, and she smelled it right away. So I guess I don't have a very sensitive nose for bleach.
Leave bleach sit in system overnight is best to.
Old 07-11-2013, 03:06 PM   #12
VinceU's Avatar
Maybe your bleach is expired? It can't hold the CL gas for long esp if the container was previously.
Old 07-11-2013, 03:15 PM   #13
ptt87's Avatar
Don't think so, pulled it from the laundry room. My wife uses bleach somewhat often, so I think its probably still good.
Pete & Laurel
Peachtree City, GA
2012 Surveyor SP280
2007 Ford F-150, 4.6L V-8
Equal-i-zer
ptt87 is offline   Reply With Quote
Old 07-11-2013, 07:27 PM   #14
Next time use powdered pool shock. 1 teaspoon for up to 100 gallons. Mix well in a gallon of water then dump, in you tank. Fill your tank and using your pump, run each faucet. You should get a very faint smell of a swimming pool. Top off you fw tank again. Let sit for at least 3 hours, drain and flush once. Take a sniff and you'll find no chlorine smell. A 1 lb bag runs less than $3.00 and will last you for years. It is extremely corrosive so be sure to keep it in a sealed container.
propbndr is offline   Reply With Quote
