Old 07-11-2013, 11:36 AM   #1
ptt87's Avatar
Sanitizing System - Chlorine Smell
I apologize up front if this sounds like a dumb question.....
I'm de-winterizing my camper and sanitizing the water system. I've already added the water-bleach solution per the manual's instructions and re-filled the fresh tank. Turned on the water pump and each faucet one at a time - the manual says until I smell the chlorine.
So my question is....how distinct is the chlorine/bleach smell? I ran my faucets for a good couple of minutes, and if there is any smell at all, its barely even noticeable.
Thanks!
Pete & Laurel
Peachtree City, GA
2012 Surveyor SP280
2007 Ford F-150, 4.6L V-8
Equal-i-zer
ptt87 is offline   Reply With Quote
Old 07-11-2013, 11:41 AM   #2
Dave_Monica's Avatar
How much bleach did you add?
Dave
Old 07-11-2013, 01:46 PM   #3
ptt87's Avatar
I used 1/4 cup bleach per gallon of water to make the solution. My tank is 36 gallons, so I used 2 1/2 gallons of solution.
Pete & Laurel
Peachtree City, GA
2012 Surveyor SP280
Equal-i-zer
Old 07-11-2013, 02:12 PM   #4
TURBS's Avatar
Oh my !
1/4 to 1/2 cup per 15 gallons is PLENTY!
Turbs
Old 07-11-2013, 02:25 PM   #5
KMP44's Avatar
Originally Posted by f1100turbo View Post
Oh my !
Turbs
I read the post as 2 1/2 gallons of "solution" with 1/4c of bleach per gallon of solution, so that would be 5/8 of a cup of bleach - about right for the tank.
Maybe run the faucets a couple more minutes. Bleach is pretty strong smelling, even at low concentration.
2017 F-250
2013 Rockwood Roo 23 IKSS
KMP44 is offline   Reply With Quote
Old 07-11-2013, 02:25 PM   #6
Most folks complain about the chorine smell using only what Turbs said and want to know how to get rid of it. Box of baking soda in 36 gallons is usually plenty. Can also cause some mild cases of "burping" and other means of relief.
Old 07-11-2013, 02:42 PM   #7
TURBS's Avatar
Sanitizing your RV SystemIt is recommended that a chlorine solution of one gallon of water and ˝ cup of chlorine bleach (Clorox) (5% sodium-hypochlorite solution) be prepared for every 15 gallons of fresh water tank capacity.To sanitize your water system in your RV will require the following solution:1. Drain the fresh water tank by opening the drain valves. There is one valve for each water tank. All of the faucets on the RV should be in the closed or off position.
http://www.rvtechlibrary.com/plumbing/sanitizing.htm
No wonder u have a serious bleach smell!
Old 07-11-2013, 02:47 PM   #8
...So my question is....how distinct is the chlorine/bleach smell? I ran my faucets for a good couple of minutes, and if there is any smell at all, its barely even noticeable.
Thanks!
...No wonder u have a serious bleach smell!
From his statement, he doesn't have a noticeable smell. Why he doesn't is beyond me!
Old 07-11-2013, 02:49 PM   #9
TURBS's Avatar
Sorry I missed that.....
I'm surpised the smell isnt blowing you out!
Op.. you do have your w.h. bypassed yet right ? Right?
Old 07-11-2013, 02:58 PM   #10
ptt87's Avatar
Yes, the water heater is currently in bypass mode from being winterized.
I just ran the faucets a little longer and I still don't smell a strong odor. So I had my daughter come in with me, and she smelled it right away. So I guess I don't have a very sensitive nose for bleach.
Pete & Laurel
Peachtree City, GA
2012 Surveyor SP280
Equal-i-zer
