Old 03-02-2018, 06:28 PM   #1
BamaGrad's Avatar
Screen filter froze and busted
Hi all
Dewinterizing for spring break and found the item below had frozen and busted. It is inline before the water pump and has a small screen inside. I need to order a new one but have no ideal what to search for. No names or part numbers on the item.
ID:	163907   Click image for larger version
ID:	163908   Click image for larger version
R & J
2015 Sunseeker 3170DS
2007 Ford Escape Toad-5 spd manual
Blue Ox Alpha tow bar/Blue Ox Patriot brake
BamaGrad is offline   Reply With Quote
Old 03-02-2018, 06:44 PM   #2
Mine did that a couple years ago. Now I remove it when I winterize. I think I searched Campingworlds website and then ordered it on Amazon!
Phil
PhilG is offline   Reply With Quote
Old 03-02-2018, 07:03 PM   #3
A32Deuce's Avatar
Sediment filter.
A32Deuce is offline   Reply With Quote
Old 03-02-2018, 07:05 PM   #4
keith52's Avatar
Get the make and model number of your water pump and search for that pump and the inline filter
2014 Chevy CC Duramax 4X4 Long Bed
2017 Cedar Creek 36CKTS
MORryde independent suspension with disc brakes
keith52 is offline   Reply With Quote
Old 03-02-2018, 07:05 PM   #5
Always Learning
Here you go. Screen filter, or strainer.
https://www.amazon.com/s/ref=nb_sb_n...o+filter&ajr=0
Old 03-02-2018, 07:12 PM   #6
BamaGrad's Avatar
Awesome. Thanks everyone. Yes, I will just remove it next time.
Randy S.
R & J
Old 03-02-2018, 11:10 PM   #7
Always Learning
Out of curiosity- did you push anti-freeze into the system or just blow out the lines?
Old 03-02-2018, 11:14 PM   #8
BamaGrad's Avatar
Blow out. Obviously not enough. We are in central Alabama. Blow out has been sufficient for the last two winters but not this year.
R & J
Old 03-02-2018, 11:24 PM   #9
Always Learning
Dang. What a weird and cold winter it was this year!
Old 03-03-2018, 07:36 AM   #10
A32Deuce's Avatar
Problem is, this is in between the fresh water tank and the pump. I found that after you drain the tank to run the pump. This empties the line, filter and also half empties my water filter. Happened to me the first year. (2012) since I have been doing it this way, has not frozen. I DO not want anti freeze in my Fresh Water Tank!
Old 03-03-2018, 07:41 AM   #11
Solution: Don't put anti freeze in your fresh water tank. Most suck it out of a bottle or bucket, right at the pump inlet.
TheWolfPaq82 is offline   Reply With Quote
Old 03-03-2018, 08:49 AM   #12
A32Deuce's Avatar
Talking about the sediment filter before the water pump. Only way to keep from freezing is af in tank, take apart and dry out, or try the way I have been for the last 5 years. You can cut the line before the filter and put in a valve with a T fitting and line and suck AF that way, That's too much like work!
Old 03-03-2018, 01:14 PM   #13
Pretty much standard and carried by most RV stores. Costs a few bucks.
DrLewie
Flemington, NJ
Former: 2007 Cardinal 30W LE
Now:2018 Arctic Fox 27-5L
2008 Ford F-250 Long Bed Diesel
Total of 30 Months on the Road Since 2008
DrLewie is offline   Reply With Quote
Old 03-03-2018, 04:02 PM   #14
As some other respondents said, that is actually a sediment filter, and as such, it should be mounted so that the bowl is hanging DOWN on the line so any type of sediment falls into it and stays there. I've seen pictures of it mounted sideways on water lines and wonder how much sediment just flows through then. When blowing out the lines water will stay in the bowl and then break the bowl if it freezes. It is also easy to forget to let shower lines hang down to drain and to blow out the toilet line (which I also neglected to do one fall.)
dsiegler is offline   Reply With Quote
