Old 02-28-2018, 05:49 PM   #1
TsnTexas's Avatar
Screen filter on Toilet
My Dometic 300 toilet doesn't add water to the bowl except a for a very light trickle. (No joke - it's not very old). I read in the manual to check the supply line filter for sand, but I can't find it. I disconnected the supply line at the inlet valve thinking it should be there, but it's not. (I did however find a very chewed up gasket at that junction which is not usable anymore - I'll have to try to find a new one of those). So just where is the inline screen filter? Thanks in advance.
Here's a pic of the gasket I need to find.
Name:	Toilet Valve Gasket.jpg
2016 Rockwood 2504s
2016 Chevy 2500HD
TsnTexas is offline   Reply With Quote
Old 02-28-2018, 07:13 PM   #2
bubbles's Avatar
It is not a filter per say it is just a waffle hole plastic that is just inside the port where the water supply is attached. It's non removal. This is what is on the 310/320.
Old 02-28-2018, 07:23 PM   #3
bubbles's Avatar
I have used a toothpick to pull blockage from inside the port that the strainer had blocked. Unless that gasket was blocking the input water line it does sound as though the strainer blockage might be your issue. That gasket is a common gasket for 1/2 inch pex tubing connections.
Old 02-28-2018, 07:35 PM   #4
Ok here's what I do.Put a towel down on the floor, disconnect the water line and pull it away from the fitting. Get one of the bendy straws (that you use for drinking) put it in the toilet fitting and blow hard. All the gunk will fly out, put the water hose back, and you're good to go(pun intended) for another 6 months.
John & Susan, Olivia the dachshund
2011 Georgetown 337DS
2003 Dodge Dakota
Hampton Roads VA
2016 174 Days camping, 2017 66 days 2018 24 days 2019 31 days
mogman is offline   Reply With Quote
Old 03-01-2018, 01:54 PM   #5
External water filter
Attachment 163749
Use one of these when you connect to campground water or fill your tanks and the problem won't recur.
Larry
Larry-NC is offline   Reply With Quote
Old 03-01-2018, 02:33 PM   #6
BobHanke's Avatar
We had that "trickle problem" also. After shutting off city water and/or the water pump, I open the outdoor shower cold valve in the basement to relieve pressure. Then I put a plastic grocery bag around the peddle valve assembly and spray it out with canned air that I use for computer keyboards. As this is a blind shot, I give it an ample spraying. Then wrap the thread with Teflon tape and leave a paper towel under for a bit to be sure it doesn't leak.
"Lurch" = Georgetown 2011 330TS
Jeep 2016 Cherokee
Pilot = Bob
Navigator = Xiangbing
Crew = NaNa & NiuNiu
BobHanke is offline   Reply With Quote
Old 03-01-2018, 02:50 PM   #7
bubbles's Avatar
Larry
The clogging typically comes from within and the use of an external or the built in filter will not help. I think it comes down to winterization procedures and the occasional draining.
Old 03-01-2018, 03:17 PM   #8
See photos.
Name:	toilet valve.png
ID:	163838   Click image for larger version
ID:	163840   Click image for larger version
Name:	toilet valve screen.jpg
Days Camped: '16=46 '17=30 '18=51 '19=36
Old 03-01-2018, 03:24 PM   #9
AKA: 'tiredTeacher
awellis3's Avatar
Thanks, 5picker!
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 03-01-2018, 03:43 PM   #10
card16's Avatar
Thanks 5picker, pictures are worth a thousand words.
card16 is offline   Reply With Quote
