Old 01-26-2015, 03:58 PM   #1
Tucson Joe's Avatar
Sensors stuck on full
Had the black tank sucked out while dry camping in Quartsite AZ.
Now the sensor reads full. Any help how to get rid of the full lights?
Thanks in advance to all who help.
2014 Ford F450 4+4
2009 XLR 40X12
2009 RZR ready for the trail
2014 RZR XP 1000
Days camped in '16 - 87
Days Camped in '17- 62
Tucson Joe is offline   Reply With Quote
Old 01-26-2015, 04:20 PM   #2
Herk7769's Avatar
So, this is a common problem with using the "sucker" method of dumping the black tank. Without the ability to turbo flush after dumping, sludge and slime on the walls will short out the terminals for your indication system.
This video will explain the problem and will show one way to prevent it; there are others, but I chose them.
https://www.youtube.com/watch?x-yt-c...-ts=1421914688
HAM CALLSIGN - KC3FFW
Old 01-26-2015, 05:45 PM   #3
TGR
TGR's Avatar
A bag or 2 of ice cubes dumped in the toilet along with a few gallons of water will clean the black holding tank while you drive. The ice scrubs the tank and then melts.
2015 Wildcat 282 RKX
2011 F350 Lariat, 6.7 L. Diesel, 8 ft., SRW, Reese R20
TGR is offline   Reply With Quote
Old 01-26-2015, 05:47 PM   #4
Herk7769's Avatar
This does not work as well as "the net" would lead you to believe.
When set up at a campground with a pump out service, not being able to turbo flush is a real issue.
Old 01-26-2015, 06:03 PM   #5
Flybob's Avatar
See this video for an actual demonstration
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 01-26-2015, 06:22 PM   #6
X2. A hot water sit followed by a turbo flush is about the only effective way I'm aware of.. and I just about seen it all. The ice cube method 'seems' to make perfect sense, but that's just not the way the world turns.
There ARE some pretty decent sensor replacements out on the market, but for the most part, it's just learning to recognize the signs.. burping, change in pitch in your gray tanks, etc.
rana is offline   Reply With Quote
Old 01-26-2015, 06:39 PM   #7
Ret E-9 Anchor-clanker
donanddona's Avatar
When you get ready to leave fill the black tank with water. Pour some tank cleaner in her and drive it. On the home stop at a dump station close to home and flush her for 30-45 minutes. If that don't work repeat the process. Most sensor cleaners will list similar direction. The key will be lots of water. Good luck!
donanddona is offline   Reply With Quote
Old 01-26-2015, 08:25 PM   #8
Herk7769's Avatar
I watched the video! Great and lots of fun.
You will be better off using a product like RV-Digest-It or RID-X to dissolve that crud. A 24-72 hour soak will eat up all the slime and sludge allowing your next pump out to flow a lot smoother.
Old 01-26-2015, 09:53 PM   #9
Tucson Joe's Avatar
Thanks all. I will watch the video and see what happens. Will try the others also if needed.
2014 Ford F450 4+4
2009 XLR 40X12
2014 RZR XP 1000
Old 01-27-2015, 12:52 AM   #10
Mojojojo's Avatar
Add a powder water softener to the tank it helps breakup build up and detaches crusts from the tank. Disbelieved it the first time I was told but did it any ways after a 6x flush and you wouldn't belie the crud coming out right after a full 2 flushes of clear water. You need to let it soak overnight. We now add it to every fill of our black tanks.
My wife keeps saying I don't listen to her -Or something like that?...."My advice has no basis ,more reliable them my own meandering experience" Baz Luhrmann
2011 Sierra 355QBQ 1986 F350
Mojojojo is offline   Reply With Quote
