Old 02-13-2015, 10:40 PM   #1
trains99
Sewage on pass through floor
I have a sewer problem. About a week ago I started to smell sewage. I drained the tank and tried to fill it up with water. Took a flashlight to check how much water I was getting in the black tank. When I felt it was getting full, I heard a gurgling and stopped and dumped. Still a smell. When I crawled in my pass-through to follow the black pipe from the toilet to the start of the underbelly (where I believe the toilet pipe connects to the black tank) there is a small pool of sewer there. HELP There is no drips or evidence of water on the pipe.
trains94054 is offline   Reply With Quote
Old 02-14-2015, 09:40 AM   #2
jtstromsburg's Avatar
I would carefully, with an assistant, fill the black tank thru the toilet, while your are laying near, but not under the suspect area. Use a flashlight and maybe an inspection mirror to watch for any signs of leaks. Could've been from how you got water into the tank? Were you using black tank flush or ?
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 02-14-2015, 09:59 AM   #3
Witch Doctor's Avatar
It could be a small leak running down the side of the PVC pipe from the flange at the toilet it self. Wipe the pipe dry and fill the or flush the toilet and see if the pipe is wet at all. Leaks love to travel. I can't see how your crawl space could get wet from the tank itself. You might have to drop the bottom or cut an access whole at the tank and feel the top and see if it is wet at all.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 02-14-2015, 10:06 AM   #4
trains99
Thanks for your help. I can't get under the suspected area. There is just a small hole where the toilet drainpipe is going to the holding tank. This may be beyond me.
Old 02-14-2015, 12:52 PM   #5
woodsman's Avatar
The use of a small mirror(dental), camera(viedo) would be helpful.
woodsman is offline   Reply With Quote
Old 02-14-2015, 01:06 PM   #6
Mojojojo's Avatar
If you overfilled the tank and the toilet down pipe isn't sealed to the tank it will come back up and could splash high enough to met the sub floor but the under side will be much wetter then the top. Also a crack in the tank close to the inlet could splash up water when flushing.
My wife keeps saying I don't listen to her -Or something like that?...."My advice has no basis ,more reliable them my own meandering experience" Baz Luhrmann
2011 Sierra 355QBQ 1986 F350
Mojojojo is offline   Reply With Quote
Old 02-14-2015, 01:25 PM   #7
Ret E-9 Anchor-clanker
donanddona's Avatar
Do you have a idea how full the black tank was when you started smelling the odor? It may have been over full (been there done that). My vent pipe leaked and wetted the floor and the inside space of the wall. At my pass thru area I had to remove the wall and clean and clean to get rid of the smell. But in the long and lots of worser words, it worked. Needless to say I pay closer attention now.
donanddona is offline   Reply With Quote
Old 02-17-2015, 12:27 PM   #8
It would be helpful to responders to know that rig you have.
2013 Flagstaff 8528IKWS, 2006 F-350 6.0L
DickiedooFlagman is offline   Reply With Quote
Old 02-17-2015, 12:34 PM   #9
Crusader 320 5w Youroo!!
Old 02-17-2015, 12:45 PM   #10
FR replaced the entire roof on our trailer under warranty. On return from FR, we experienced grey water leaking on the ground. (The tank is located in the basement underneath the floor.) The dealer found that the vent pipe from the roof into the grey tank was installed incorrectly. The vent pipe pushes through a rubber gasket and the gasket/pipe connection was incorrectly sealed (friction fit). Dealer and all is good now.
